Question about Rangemaster 110 (Gas) Kitchen Range
Gas leak on dual fuel leisure cooker
Is it worth fiXing
    New Friend:
How old is it ? Does it have a warranty? Do you want to keep it?
If you like the appliance then yes but you will need a gas fitter to find the leak and fix it. How do you know it has a gas leak?
Posted on Jan 20, 2013
I have a leisure range cooker. model number CMTF99R.The oven RHSis not Heating up. the fan is working and the thermostat light is coming on.
Check for voltage at the element, could be a hi-limit thermostat or a failure at the control board.... You may find you are missing one leg (half) of the 240VAC required to power the elements
Jul 31, 2016 | Leisure Range 90 CMTF95C Cream 900 mm Dual...
Cooker makes popping noise when off
It\'s possible you have a slow leak through one of the rail cocks ( gas taps) lift off the top and spray lightly some soapy water on the end of each of the rail cocks if it bubbles you have found the leak.
Apr 13, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
Gas cooker
Probably. Speak with your propane supplier about what will need to be done with your stove.
May 03, 2010 | Belling DB2 Dual Fuel (Electric and Gas)...
I have a leisure rangemaster 110 dual fuel cooker. The auto timer has gone wrong. How can I bypass this timer
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me info@topoftherangeltd.co.uk
Feb 12, 2010 | Rangemaster 110 (Dual Fuel) Dual Fuel...
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Rangemaster 110 (Gas) Kitchen Range Logo
111 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
