Question about Philips Televison & Video
VESA screw size for Philips TV - Philips Televison & Video
5 Suggested Answers
  • 476 Answers
SOURCE: vesa screw holes
Most wall brackets are universal for a particular vesa standard, in this case 100mm x 200mm.
This means that the bolts supplied aren't for any particular set.
The Philips 26PF5521D only needs bolts up to about 12mm long.
Try shorter bolts.
Posted on Feb 22, 2008
SOURCE: philips tv mounting problems
did you ever find a solution for this? the same thing happened to me, and now philips wont repair the mounting hole. I am so mad and will never buy another Philips again!
Posted on Jan 19, 2010
SOURCE: VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Posted on Oct 08, 2010
SOURCE: MNTR SMSNG|LCD 24" 5MS B2430HD RT I am looking for
Sansung Custermer Service told me these screws were an odd size and offered to send the screws to me. 8 week and 6 phone calls later and still no screws!!
I have tried M5 and M4 and both were too large. I'm trying to source M3's and hope they will fit, otherwise I'll return the TV to Costco.....
Posted on Dec 29, 2010
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
We want to wall mount thevTV what size screw fits the back of the TV? Sanyo model DP32649
Assuming a modern TV with a square/rectangular arrangement of holes (i.e. VESA mount) - they're M4, length varies.
Appropriate screws will be in the kit with the wall bracket.
Nov 08, 2014 | Televison & Video
I have 1 tv Thomson 32E92NH22 LCD and i lost the manual.I'm trying to get it hanged on the wall.No ideea what tipe of screw i need to conect the tv to the wall hanger.Can somebody halpe me?Thanx a...
Hi mona_77a,
You can find the manual for your TV here.
Your Thomson TV is compatible with a VESA FDMI (Flat Display Mounting Interface.)
These typically use "VESA screws."
VESA screws tend to be metric sizes of M4 (0.7mm pitch). The length is typically 10mm, but would depend on the bracket (if you don't have a gauge handy, just put a small stick of some sort in there and mark it off with a felt pen, then measure).
Washers are a really good idea, especially if you decide on thumbscrews with plastic heads.
You may be interested in eHow's tutorial on how to mount a flatscreen TV to a wall. This is for a 42 inch screen, but the same rules should apply with a 32 inch.
  • Open Link in New Tab
  • Download
Mar 01, 2011 | Televison & Video
MNTR SMSNG|LCD 24" 5MS B2430HD RT I am looking for the screw size to mount this monitor to a vesa comapatible wall mount.
Oct 15, 2010 | Samsung B2430H 24Inch Widescreen LCD...
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Philips tv mounting problems
Dec 26, 2009 | Philips 42PFL3704D LCD TV
I want to buy and install HTS8140 on my 47PFL9632D TV. The TV is not wall mount and the idea is to be able to swivel both together.
There are universal mounts available that clamp to the tv screen instead of screwing into the back. They are called non-VESA wall mounts. Check BestBuy.
Nov 08, 2009 | Philips Televison & Video
Vesa screw holes
Try shorter bolts.
Sep 27, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
