Question about Epson V600 Flatbed Scanner
V600 when I scan it looks good in preview but is terrible in the actual can
I am scanning photos and cocuments, the ducnments old newspaper, certicates etc are elegible when printed, I don't need OCR I just need it to stop coing out blotchy and unusable
  • 110 Answers
SOURCE: Scanner wont scan transparencies properly
On the 4990, make sure that you have unlocked the lid of the scanner. The lock is located underneath the lid.
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
SOURCE: Epson 4490: where'd my "film" option go?
I had this problem, turned out the cable between the lid and the main chassis of the scanner had pulled out slightly. Plug it in and problem solved.
Posted on Jun 02, 2009
  • 35 Answers
SOURCE: I cannot get clear scans from my photo negatives
If you are seeing pixelation, the issue is either insufficient resolution during the scanning process or a problem with the output device. If it's a focus issue, which will NOT cause pixelation, the problem may be the height of the negative holder. The Epson Perfection V series scanners have a fixed focus point which only adjusts between two settings depending on whether you select the film holders (which raise the film off the glass) or the film guide (which scans film directly on the glass) in the software options. If you are going to scan transparencies or negatives, familiarize yourself with the holder height adjustment issue and be willing to experiment with different height settings until you are getting optimum results. This is not documented much at all in the Epson user manual but there is a little bit about it, including some examples of results at different settings, here: http://www.photo-i.co.uk/Reviews/interactive/Epson%20V700/page_13.htm Apparently every scanner is slightly different so even though the lowest holder foot setting (default) is working best for some, other settings work better for others. On my V700, I have the feet on the film holders set to the highest setting plus I shimmed them with a 1mm piece of styrene before I could get the scans in focus. Once I found the right height though, I've been able to get beautiful scans from this machine. BTW, scanning negs directly on the glass will almost always result in Newton Rings.
Posted on Jun 14, 2009
SOURCE: Epson V300 Photo Scanner Streak When Scanning Negative
I also own a v300, and I have noticed that I occasionally get rainbow streaks if I bump the scanner at all while it is scanning negatives, so this might have something to do with vibrations in the machine. Is it sitting on a stable surface?
Posted on Aug 05, 2009
chinpokojed
SOURCE: Epson 1640SU scanner, red line in all previews and scans
Most likely it is a spec of dust on the scanning sensor.  I recommend cleaning with a soft cloth and isopropyl alcohol.  More info here -  http://www.willshak.com/scanner/
Posted on Dec 24, 2009
When scanning a color picture it comes through in black and white what am i doing wrong?
Change the Options on your HP Scanning Software to Scan in Colour or Else:
In this case u have to scan and Preview the scanned images using Windows Photo Gallery.....
Click on File and Click on Import from scanner or Camera...........
Then again click on Import...........It will scan and preview the Applications to u....
Thanku.......
Good Luck!@@!
Sep 23, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
How do I scan with HP psc 1210
Answer is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&lc=en&dlc=en&cc=us&product=90764#N305
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 24, 2011 | HP PSC 1210 All-In-One InkJet Printer
How do I scan a picture and email it?
Hi
You can start a scan from your computer or from your HP OfficeJet.
to scan an original from your Windows computer
1 Load your original either on the glass or in the automatic document feeder
(ADF).
2 Press Start Scan.
A scan of the original appears in the HP Preview window.
3 In the HP Preview, you can edit the scanned image. When you have
finished, click Accept.
For more information about making changes to an image during the
preview, see adjust an image during the preview in scan pictures and
documents in the HP Photo & Imaging Help for more information.
The HP OfficeJet does a final scan of the original and sends the image to
the HP Photo & Imaging Gallery.
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
How do I scan photos
Although different scanner has different option still I am giving you the general method of scanning.
Put the photo on the scanner (photo face down touching the glass of the scanner) - look the cover is perfectly placed and no light is entering inside of the scanner. Now run the scanner software - select scan item as "Photo" (other options are text or documents etc), select the option "Color" (other option is Black and white or gray ). Select the resolution more than 200 dpi (more dpi will give better output), give path where the file will be saved after scanning or keep it default, choose the file type JPEG is better (other options may be BMP, TIF etc). First you get preview - look the expected scan output - if required you adjust or lace the photo on the scanner better way - then again get preview - if you are satisfied you may select the portion out of the whole preview page for scanning - now click scan. It will give JPEG file in the specified location.
Jun 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Scanner not scanning right. scans in sections. i need to scan a standard size sheet of paper and it scans it in peices. how do i get it to scan this document correctly
You need to set the scanner to scan a standard size paper (letter or A4) in the Scan Settings dialog. To get there, from the MP Navigator select "Scan Photo/Document", then on the lower left side of the preview area click on the "Specify. ." button. Your Document Size is probably set at "Auto Detect (Multiple Documents)". Change this to the size document you are scanning and click "OK". Now you can preview and scan and not have segmented images.
Mar 03, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Scanning o.k and then on 4th scan made a terrible racket during preview and now doesn't work at all. totally dead
mustek is old and outdated equipment the noise you heard as i have from many of those old dinasour's is the gear drive in the tray area shattered and there best tossed in the trash not really cost effective to repair them
Jan 14, 2010 | Mustek A3 USB Flatbed Scanner
When scanning old photo, scanner stretches the image. how do i get it to scan image to same proportion as original?
Open Epson Scan and select Professional mode. Turn off the Auto Thumbnail option. Leave the target size As Original and then do a preview. Once the preveiw is complete in the preview windows draw a marquee around the area you want to scan and select scan.
Dec 24, 2009 | Epson Perfection 4490 Film / Flatbed...
The scan comes out as a solid black image both in the preview and in the actual scan.
This is a preview from a related model, you must set the profile to photo and the color format of your reference. Hope this helps.
Nov 18, 2009 | Brother MFC 4800 All-In-One Laser Printer
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Epson perfection 4990 photo scanner
Sep 25, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson V600 Flatbed Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
