Question about Sharp Office Equipment & Supplies
Sharp ar-c160 fiery stays on 'BOOTING"
Does any one have the installation software cd for the sharp ar-pe2 fiery?. I have 4 of these machines with all but one with the same problem (stays on "booting printer controller"). I want to use these machines because of the high gloss finish they deliver on gloss 80lb. covers.
  • Sharp Expert
  • 337 Answers
Bye bye fiery. are they embedded or standalone via scsi?
Posted on Jan 30, 2013
  • keith saunders Mar 05, 2013
    the fiery ar-pe2 is an embedded printer controller thats fits to the back of the sharp ar-c160 copier.
  • 208 Answers
SOURCE: Driver for sharp ar 5316 driver for my RHEL 5 machine
You can also go to Xerox.com and select support and downloads.
Type in WCP215 it is the same driver.
Posted on Dec 20, 2007
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 62 Answers
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Posted on Jul 30, 2008
  • 148 Answers
SOURCE: Sharp AR C160 - Error H4-00
The thermistor inside of the fuser needs to be reset before you can clear the code. If you remove the top cover of the fuser the thermistor is located on top of the upper fusser roller. It should be reset able by pushing in. Then you put in the reset code. you may want a tech to look into what caused this.
Hope that helps...
Lbcoaster
Posted on Sep 16, 2008
  • 87 Answers
SOURCE: F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Posted on Dec 18, 2008
Missing my AR 5316 Driver CD. Pleass Send this Driver software my email address.
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Select
AR5316 > Windows (XP, Vista, Windows 7 etc) Depending upon the OS you have.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error code L4-05 for Sharp AR-C160 Digital
main motor lock detection
shifter motor trouble
Nov 26, 2009 | Sharp AR-C160 Color Copier
My fiery EXP 12 not booting what can I do to fix this problem
You should be able to plug a monitor into the fiery. Do that and turn off the machine and fiery. Then power up and watch the monitor and see where it hangs. If it doesn't boot up you may have to get a Xerox technician in to restore/ugrade the system software for the fiery.
Nov 22, 2009 | Xerox DocuColor 12 Color Copier
I CANT INSTALL SHARP AR-5316/5320 SOFTWARE CD-ROM IN WINDOWS VISTA
most of the time the CD rom the machine comes with is no good
try to download the software from the website
Jul 08, 2009 | Sharp AR-5320 Black and White Copier
F2 ERROR CODE
Oct 22, 2008 | Sharp AR-C160 Color Copier
Error code F2-45
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Jul 18, 2008 | Sharp AR-C160 Color Copier
Sharp AR-C160
replace color extraction unit .
Apr 25, 2008 | Sharp AR-C160 Color Copier
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Dec 16, 2007 | Sharp AR-C160 Color Copier
Sharp AR160 - need reboot systems disk for fiery computer
PLEAZ OPEN THE SHARP COPIERS WEB SIDE AND SEE THE NUMBER OF YOUR ARIA
Sep 14, 2007 | Sharp AR-160 Copier
Calling for toner. toner full.
toner is not going in the developer
Dec 13, 2006 | Sharp AR-C160 Color Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
