Question about Proscan Televison & Video
PROSCAN PLED3216A PROGRAMING DIRECT TV REMOTE
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: need codes for proscan
phone_header_def.png saveupto_a.png phone_callnow_def.png DIRECTV Specials DIRECTV Packages DIRECTV Receivers DIRECTV DVR DIRECTV HD DIRECTV vs. Cable DIRECTV vs. Dish DIRECTV Sports Home > Remote Codes DIRECTV Remote Codes remote_codes_header.jpg TV CODES VCR CODES DVD CODES STEREO RECEIVER CODES
STEREO AMPLIFIER CODES DIRECTV RECEIVER CODES
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Posted on May 06, 2009
  • 10865 Answers
SOURCE: need the code for proscan to work with direct TV
here is the complete list of codes, and proscan is in there
http://www.hifi-remote.com/ofa/devices-tv.shtml
Posted on Jun 08, 2009
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Posted on Mar 17, 2009
SOURCE: Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Posted on Jul 22, 2009
I just bought a curtis tv with no remote. Is it useless?
No, just get a replacement remote.
  • Amazon.com: Customer Reviews: CURTIS INTERNATIONAL ... www.amazon.com/INTERNATIONAL-Replacement-LCD4686AW-PLED3216A-LCD... Find helpful customer reviews and review ratings for CURTIS INTERNATIONAL Replacement Remote Control for LCD4686AW, PLED3216A, LCD3235A, LCD3227A ...
  • www.amazon.com www.amazon.com/INTERNATIONAL-Replacement-LCD4686AW-PLED3216A-LCD... We would like to show you a description here but the site won't allow us.
  • discount replacement CURTIS tv remote controls original ... www.electronicadventure.us/curtis.htm Enter your Curtis remote part number or the model number of your TV, DVD, Audio, etc in search box, or manually search below:
  • Buy CURTIS LCD3227A Remote Control $29.95 - REMOTES ... www.remotes-express.com/Curtis/LCD3227A.html CURTIS LCD3227A Remote Control This CURTIS LCD3227A is only one of the many Curtis remote controls we carry. Enjoy the full functionality of on-screen menus and ...
  • Amazon.com: CURTIS INTERNATIONAL Replacement Remote ... www.amazon.com > ... > Remote Controls > TV Remote Controls z Amazon.com: CURTIS INTERNATIONAL Replacement Remote Control for LEDVD1975A2, LCDVD2234A, LCDVD199A2, LCDVD2454A: Electronics
  • CURTIS INTERNATIONAL Replacement Remote Control for ... www.ebay.com/sch/sis.html?_nkw=CURTIS+INTERNATIONAL+Replacement... Find best value and selection for your CURTIS INTERNATIONAL Replacement Remote Control for LCD2425A LCD3227A LCD3708A search on eBay. World's leading ...
  • CURTIS LCD3215A LCD3215E LCD3216E LCD3227A LCD3235A ... www.ebay.ca/sch/sis.html?_nkw=CURTIS+LCD3215A+LCD3215E+LCD3216E... CURTIS LCD3215A LCD3215E LCD3216E LCD3227A LCD3235A TV AC 2 AC POWER CORD 0 results. ... Replacement Remote for CURTIS INTERNATIONAL ...
  • Replacement Remote CURTIS INTERNATIONAL DVD6019B ' ... www.ebay.ca/sch/sis.html?_nkw=Replacement+Remote+CURTIS... Find best value and selection for your Replacement Remote CURTIS INTERNATIONAL DVD6019B search on eBay. World's leading marketplace.
  • Redi-Remote CURTIS INTERNATIONAL Replacement Remote ... www.sears.com/redi-remote-curtis-international-replacement-remote... CURTIS INTERNATIONAL Replacement Remote Control for LCD4686AW, PLED3216A, LCD3235A, LCD3227A. This is a custom built replacement remote made by Redi Remote ...
  • CURTIS LCD3227A - RemoteControls.com ' Remote Controls www.remotecontrols.com/product/LCD3227A.html CURTIS; CURTIS LCD3227A; CURTIS LCD3227A. Price: $29.95. Code: LCD3227A. Weight: 1.00 pounds. ... So if you return the remote a few days after the 30 days - no ...
  • May 28, 2016 | Curtis LCD3227A 32-inch LCD TV
    Proscan pled3216a tv went black but still have sound?
    Problem on [Main Board] it's the board where your cable or antenna plugs in.
    Col. Dana Gillespie
    Nov 28, 2014 | Proscan Televison & Video
    I need a tv code for a Comcast remote for my 32"
    0045 0049 0076 0101 0110. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
    http://electro-medical.blogspot.com/
    http://remotesearch.blogspot.com/
    http://electrohelponline.blogspot.com/
    Sep 20, 2014 | Televison & Video
    Proscan website
    Depend on the manufacturer. You may able to install.
    Oct 22, 2013 | Televison & Video
    My remote quit working.
    If ur direct tv remote have problems,or it defective.Talk to ur direct tv satalite provider to get another remote.U can try website like 1-800-Remotes factory original.To buy ur Proscan tv original remote.
    May 03, 2010 | Proscan 32LB30QD 32 in. LCD TV
    I need to program 2 direct tv remotes to operate tv's as well as the direct tv box
    here is a link with the code sets for this remote: direct TV remote codes
    here is a link to programing guides: Programing a remote
    choose your remote type and follow the instructions to program it.
    Thanks and I hope I helped. Send a message if you have any questions.
    Mar 17, 2010 | RCA DIRECTV Satellite Remote Control
    Remote code for comcast dvr/proscan tv
    I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
    May 23, 2009 | Samsung DVD-HD845 DVD Player
    I can't program a Direct TV remote for Proscan TV
    Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST
    For Universal Remote Control brands listed below, please use accompanying Proscan codes
    and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
    operate Proscan model.
    Proscan codes for Sony TV=8003,8012
    Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
    Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
    May 16, 2009 | Proscan 32LA30Q Television
    32" proscan dual hd tv can't get universal or direct tv remote to work what now
    Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
    Craig www.classtorations.com
    Jun 08, 2008 | Proscan PS32500 32" TV
    Manual for Proscan 32" LCD TV
    http://www.oncorpus.com/down/down.htm
    This is the site for the Proscan manufacturer. Should be able to get answers and/or tech support.
    Jan 18, 2008 | Proscan 32LA30Q Television
    Televison & Video Logo
    142 people viewed this question
    Top Proscan Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Jaime Hernandez
    Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
