Question about Exercise & Fitness
Steelflex xt2700 won't start
Just bought a second hand treadmill but when I power it up all I get is all dashes on the display
    Top Expert:
  • 12,223 Answers
Adjust the REED switch, see the diagram , test for open or faulty. Clean it and tigh the connector very well.
2) replace the old batteries by new ones, and clean very well the contacats batteries.
3) tight the ribbon cables for keypads, and clean it, and tight the connector very well.
Posted on Jan 21, 2013
SOURCE: I have a steelflex XT-3600
1. If E6 or E7 appears during power on or during operation, turn off and restart
treadmill. If E6 or E7 still appears on the display, turn off and restart treadmill again.
If this problem persists, go to next step.
2. If the treadmill stops at higher level, press "STOP" & "DOWN" buttons at the same
time for 3-5 seconds to reset the elevation motor to bring the unit down to zero
position. Or else, press "STOP" & "UP" buttons at the same time for 3-5 seconds to
bring the unit up to zero position.
3. Turn off and restart the treadmill, the unit should show at 0% elevation and press
Quick start to begin.
Posted on Feb 25, 2011
  • 1196 Answers
SOURCE: I have a U.N.O treadmill
All powered treadmills have a breaker. The purpose of the breaker is to prevent a power surge that might damage the treadmill motor. Check the circuit breaker on the frame near the power cord. If the reset/off circuit breaker has tripped, wait 5 minutes and then reset the breaker by pressing the switch in. That should fix the problem.
Posted on May 11, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Posted on Nov 18, 2011
knight_nemes
  • 11 Answers
SOURCE: Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
Posted on May 04, 2012
  • 59 Answers
SOURCE: my treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
HORIZON Treadmill CT5.3 out off work
If you wish to get some details; check the site linked here. Pull up older posts.... http://electro-medical.blogspot.com/
Dec 08, 2016 | Exercise & Fitness
V-fit treadmill won't start and shows error message.
Test the power supply coming to the equipment and try again. If the problem with power is o.k proceed with LUBE very important. God bless you
Apr 07, 2013 | Exercise & Fitness
Not getting any digital display except power ''is on'' and thetreadmill doesnt start. Mine is a horizon CT5.2. Do i need to change the internal electronic circuit?
1) replace the old batteries by new ones with the same MARKS
2) Clean the contacts batteries, with c. cleaner very well
3) tight the Ribbon cables from keypads from display board.,and clean it
4) Adjust the REED swtich, see the diagram, clean it, and test for open or defective. tight the connector very well and try again.
God bless you
Jan 11, 2013 | Horizon 5.2t Motor Controller treadmill
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
My emage treathmill won't start and it displays a FF on the screen
Hi There,
This is in need of a new console. This is the only way to fix the problem.
Dec 25, 2012 | Icon Image 17.5 S Treadmill
Need manual for RE1000 treadmill
please download from the website www.manualslib.com
God bless you
Dec 15, 2012 | Exercise & Fitness
My xt2700 steelflex treadmill shows err1 code what is the problem amnd how do i rectify it
I an having a STEELFLEX 2700 Treadmill.
In the ELEVATION display its showing "Err7" and the running belt is elevated.Pleas kindly help me to rectify this problem.
My user manual also lost,if someone know the online manual please share the link.
Dilantha.
Mar 10, 2011 | Sport & Outdoor - Others
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
