Bosch WFK 2200 washing machine fault code 4 - what does this mean?
  • 139 Answers
SOURCE: washing machine
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump..
hope this helps cheers
Posted on Jan 21, 2008
  • 43 Answers
SOURCE: bosch exxcel 1200 express
need more info what point in the wash does it start to display the code
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: fault codes for indesit washing machine, the display shows F-08
F08 means that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
The only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Thanks.
Posted on Jan 24, 2009
SOURCE: I have E3 error code on a Bosch washing machine
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Posted on Nov 22, 2009
Code 08 on bosch wfk 2401
Faulty door switch
Aug 27, 2014 | Bosch WFK 2401
Bosch wfk2401 fault 08
Most likely this means you have a belt problem, or the brushes have worn out. If you are confident, UNPLUG the machine, and remove the back cover. It will be obvious if the belt has come off, and you may be able to re-instal the old one, or buy a new one.
Worn motor brushes will be less obvious, but if you're reasonably confident with electronics, you could remove the motor, and inspect the brushes, or get someone else to.
Sep 28, 2012 | Bosch WFK 2401
Bosch WFK 6030 manual
Please check this link, it will help you with the working operations and trouble shooting:
washing machine advice
Oct 29, 2011 | Bosch WFK 2401
What does flashing error code 2 on Bosch a WFK 2800 washing machine indicate
Problem from heating. Could be element or wires from it
Oct 21, 2010 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove drive belt.
Remove motor plug
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
I have as Bosch WFK 2200 washing machine, I can't get it to spin... Can you help please!?
Hi. If the machine is over 6 or seven years old it is possible that the wash motor brushes are worn out. Give me more info. FD number and number of washes per week.
0417362396 Melbourne metro area
Regards Sam
Dec 22, 2008 | Audiovox Bosch 718 World Cellular Phone
Fault Code 06
put the selector switch on the x setting and hit the start button it will tak 60 sec and the door will unlock
Apr 19, 2008 | Bosch WFK 2401
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
