Hi. I have a Sanyo rcs-tm80bg heating and cooling system I my house BUT when the outside temp is very cold, say 2 degrees or less, it doesn't want to throw out hot air. The fan speed does what it wants no matter what speed I use. So, today I set for 24 degrees on high speed and I get a dribble of cold air. My room is freezing! Please help.
  • 50 Answers
SOURCE: Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
Posted on May 18, 2008
SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
22yooper
  • 828 Answers
SOURCE: outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Posted on Jun 16, 2008
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
mastatech
  • 478 Answers
SOURCE: Heat Pump Cycles On and Off and Air Handler Noisy
I am pretty sure you have a low charge and the pressure switch is kicking it off. probably just a pound or two however the accumulater will sometimes hold more.
Posted on Mar 31, 2009
Why is my unit unable to cool my house more than 15 degrees below outside temp?
probably a tonnage issue. unless you have 12 inches of insulation in the attic i like to go with 400 sq. ft. per ton in the houston area. our humidity is so high it will not keep a cold enough coil to wring moisture out of air. all a/c systems are designed to operate at 95 degree ambient. when you get to 102 and more the effienecy drops off quick.
Jul 03, 2014 | Amana Heating & Cooling
Heat Pump
That is normal. Secondary heat is not needed unless it is very cold outside. If the heat pump can't keep the house warm enough and the temps start to drop, the secondary heat kicks in. 2 degrees is normal.
Aug 18, 2012 | American Standard 5000 Heat Pump Unit
M6X08F2A Air Conditioner problems not blowing cold, not cooling off apartment
Sounds like the heater is on as well. Even if ac is not working it shouldn't get hotter than outside air temp. Possible stuck relay.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 01, 2017 | Maytag Heating & Cooling
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Jan 30, 2011 | Sanyo Heating & Cooling
Poor cooling. High bills when heating.
see if the lines the big one if it is verry cold or frosted let me know
Apr 08, 2010 | Goodman GPC1330H21A Air Conditioner
My Honeywell thermostat does not heat the house to the selected temperature. It will come on but not long enough to heat the house to the temp I selected.
Verify that you have heat coming from the vents.
Also do you use a heat pump system with electric emergency heat?
It may be that if it is to cold outside that the heat pump can not handle the load due to the cold outside and you will need to turn on the emergency heat.
Keep me posted.
FlaTech.
Thank you for using FixYa!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 17, 2009 | Honeywell Heating & Cooling
Cannot set a/c to operate automatically
sound to be in heat modenow. If you are after the cool mode, then if you have a cool setting and a heat temp setting, Lower the heat to almost off and set the cool setting to 74 degrees. See if the outside coils get warm. Make sure you are off manualo and n auto. If it runs, give it some time and the tenp of the outside coil will rise and the inside will get cold. Food Luck
May 23, 2009 | Sanyo Split System Air Conditioner
Heat pump condinser freezing.
YOU HAVE ONE OF SEVERAL PROBLEMS , FIRST AND EASIEST TO REPAIR KEEP FILTERS CLEAN REPLACE EVERY 30 DAYS , #2 LOW CHARGE WILL CAUSE ICE ,# 3 A FAULTY INTERMITTENT FAN CONTROL SWITCH ,THIS WOULD BE MY # 1 GUESS SINCE I HAVE SEEN IT MANY TIME OVER THE YEARS , #3 WOULD BE A FAULTY DEFROST CONTROL BOARD OR SENSOR , THE REASON I LEAN TOWARD THE FAN CONTROL IS YOU SAY THE ICE IS ALSO IN THE INSIDE UNIT AND THIS IS MOST COMMON WITH RESTRICTED AIR FLOW OVER COILS AND SOME TIMES THE FAN SWITCH WILL CAUSE THIS PROBLEM THE DISCHARGE TEMPERATURE IS DIRECTLY RELATED TO THE TYPE OF UNIT ,TYPE OF REFRIGERANT IN SYSTEM AIR BALANCE CFM OF FLOW MANY VARIABLES IN THIS EQUATION,CANT SAY
Dec 20, 2007 | Ruud UAMB Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
