Question about Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT
Starts ok. runs for several minutes, then dies and wont restart for 5 minutes
Replaces plugs, cleaned air filter. Could it be gas cap vent?
    Top Expert:
  • Poulan Master
  • 42,546 Answers
Replace diaphrams in carby. clean or replace filter in tank on end of fuel line Ensure fuel cap allows ventilation for running.
Posted on Apr 25, 2013
My mower will run for about 30 minutes then die and then have to wait for awhile and process starts all over. i have changed oil, spark plug, plug wire and coil, fuel filter, air filter and screen,...
Try this.
When the mower is about to die, loosen the gas cap.
My mower gas cap vent holes plugged up and kept stalling the mower.
If it works, drill out the vent holes.
Gary
Jun 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Aug 20, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 16 year-old MTD lawn tracotr with a 12.5 hp briggs & strattion engine. The tractor will run for 5 minuted then quit. It appears that the n(new) fuel filter is not full, thus gas is not...
Were the engine rpm's steady when it died? If it was hunting, the carb. probably needs cleaned.
The fuel filter can maintain an air bubble in it and still flow plenty of fuel. So does it restart after it dies? You can check the cap by running with the cap a little looser and see if it dies, I have not ever encountered a cap failure, but you could look to see if the vent hole in the cap is plugged.
If you had a crack in the fuel line or were sucking air in somewhere it probably would not run right from the outset.
Aug 12, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a 18" Craftsman gas chain saw. It will not keep running, after two or three cuts it just stops and cannot be started again until it sits for 15 to 20 minutes. I have cleaned the air filter and...
Try removing the fuel cap for a moment, then try restart. If ok, check the fuel vent for plugging. Check the fuel filter for plugging. Inspect the fuel lines for decay or other damage. Check for spark when it stops--it may be the ignition module failing when hot. Check for sawdust and dirt plugging the ventilation system--blow it out with compressed air. Does the engine 4-stroke at speed when not cutting, but does 2-stroke when cutting? Make sure the chain is being oiled while running. Hope this helps!
Jul 13, 2010 | Craftsman 18" Chain Saw Replacement Bar...
Poulan 3314 Chainsaw Dies when I press throttle. Have done following: 1. Removed carb. Cleaned with Laq Thin. And blew out with comp.air. 2. Cleaned & Checked fuel filter. 3. Cleaned Air Filter. 4....
Check the muffler for plugging. Does the primer bulb fill with fuel when pumped several times. If it takes a lot of pumps to pull fuel, replace the fuel filter or maybe the primer bulb if it appears to be hard or cracked. #4--reset fuel jet 1-1/2 turns? You say further on that the H and L jet needles have not been moved. These two jets are the only adjustable fuel control there is. Did you mean the idle speed screw? Did you get a snappy blue spark at the plug when you checked it? The caps on the two tanks are usually not directly vented--there are vents inserted into the tank casting. Try spraying some starting fluid into the plug hole, install the plug and pull through. If pops several times, concentrate on the fuel system. When cleaning the carburetor, you should remove the two jet needles to wash out those cavities. Spray carburetor cleaner is a better cleaning agent for carburetors than lacquer thinner. The lower chamber diaphragm directly controls fuel within the carburetor and it must be flexible and no holes! Go to: http:// www.drystacked.com for some good carburetor theory for 2-strokes. Hope some of this helps!
Apr 12, 2010 | Garden
Have craftsman chain saw, runs ok for a few minutes then dies. found broken gas line.replaced fuel line,air filter,spark plug, checked muffler, also mixed fresh gas.eng acts like its out of gas. leave it...
The plugged vent gets my vote. Loosen the fuel cap when it starts to starve.
All Poulan IPLs (exploded parts list) are here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Find your model, what little fuel system detail there is can be found on it. HTH
Lou
Oct 04, 2009 | Garden
Craftsman Lt1000 with 21hp keeps wanting to die after 5-10 minutes, battery, plugs and air filter has been replace, any help would be great.
Have you replaced the fuel filter? My 21 horse did the same thing until I put in a new fuel filter.
HOpe this helps.
Aug 19, 2009 | Garden
This sounds too easy of a solution but I had a like ptroblem with my Craftsman. I loosed the gas cap a bit and the rough running and stalling stopped. he vent on the gas cap that contains a turn over interrupt valve was plugged causing the gas not to flow. I took the cap apart and cleaned out the vent hole though cleaning the holewith a paper clip would have worked as well. Anyway..it fixed my problem. I think my dirty hands of deris deposited the matera in the vent hole when filling with gas.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
6yr old Craftsman Lawn Tractor - Koehler 18 HP Auto. Sputter&Dies
Try running it again and when it starts to die remove the gas cap and see if it starts to run better. It's possible that the gas tank isn't venting correctly. If that doesn't work post back and we'll try to come up with some other solutions.
Apr 22, 2009 | Craftsman Garden
Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT Logo
180 people viewed this question
Top Poulan Tools & Hardware - Others Experts
L Pfaff
L Pfaff
Bill Boyd
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
