Question about Craftsman Air Tools & Compressors
My model 875.199820 impact wrench turns in both directions, but under load will not turn.
  • Brian Arneman Apr 15, 2013
    I fixed it by removing the air fitting and turning over a rubber gasket that was down inside the handle that was in backwards and therefore not seated properly. thanks for your help.
4 Suggested Answers
  • 226 Answers
SOURCE: Will not change direction
First thing i would do is to put penetrating oil around the knob that you twist as it probably is just sticking. You can remove the air motor from the top assy & clean and oil everything as long as you put it back the same way. Thats what I do. Hope this helps you, Rick
Posted on Apr 26, 2009
john631068
  • 172 Answers
SOURCE: Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Posted on Nov 17, 2009
SOURCE: Dont know where to put oil in Craftsman 1/2 " Impact wrench
I just bought one of these also. Manual says oil goes into "the air inlet" which I'm thinking is where you attach the hose. That way the oil is sprayed throughout the interior of the gun once you run air through it.
Question for you: I can't get an impact socket onto this gun, almost seems like the square hole is too small. (yes, both are 1/2" drive). How do you get a socket on this stupid thing?
(man that sounds like I'm an idiot, but I've spent a half hour leaning all my body wight, wiggling, etc. and can't get a damn socket on)
Posted on Jun 20, 2010
Air opertes but locks up under load
Sounds like you might have a problem with the hammer (clutch) mechanism, these types of impacts are direct drive there a re no gears, so the hammer (clutch) mechanism must have the ability to splip after impacting to allow the air motor to turn. Disassemble and look for broken hammer pins, hammer dogs.
If you need a parts list you can go to CP.com, powertoolrepairohio.com or ereplacementparts.com
Feb 01, 2014 | Chicago Pneumatic 1/2" Air Impact Wrench
No torque on my impact #875 198641
If you are trying to loosen or tighten a bolt or nut the the impact just stops more than likely there is a problem in the hammer (clutch) mechanism (items# 24 through 30), there could be broken part causing the mechanism to jam, the hammer (clutch) needs to hit and then slip to let the motor turn as they are directly coupled (no gears). On the flip side in the motor there are vanes (blades)
(item# 17) that need to have free movement and could also cause a condition were the motor could have low power or cause a locked condition.
Follow this link for the owner/parts manual:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Craftsman-Parts/user-manuals/manual-downloads/Model-875198641/0247/0755200?modelNumber=875198641&diagramPageId=&documentId=P0710197
Nov 11, 2013 | Craftsman 1/2" Impact Wrench
Trigger sticking can not switch on
Make sure the direction switch isn't in the middle. That keeps the trigger from inadvertently being activated.
Feb 14, 2013 | Titan Tools Model TTN-22160 24-Volt...
Impact turns but no tork why
An impact wrench works by directing air into a chamber where a hub with sliding vanes turns to do your work for you. If any of the five or six vanes are damaged the tork value will go down. It is possible for the hub to turn freely however the more air that gets past the vanes, instead of pushing on them, the lower your tork value will be. The bearings for the hub could be damaged or seized but that usually affects free spinning speed more than tork. The insides of an impact wrench are fairly simple, take it apart and check the vanes and bearings. Ingersol Rand makes rebuild kits for most of their impact wrenches.
Aug 17, 2012 | Ingersoll Rand Ir 2131qt 1/2 Impact Wrench
My directional control buttons on the gun are sticking
Ingersoll Rand impacts have o-rings that are mounted in the housing or on the valve that are susceptible to swelling and causing the reverse valve to stick!
if you know the model number, follow this link to find the appropriate manual to see the valve set up.
Ingersoll Rand Industrial Technologies On line Publications
Jan 31, 2011 | Ingersoll Rand 1/2" Air Impact Wrench Gun
I have a brand new CH Model TL050299, 1/2" impact wrench running off a 20 gal, 3.5 HP Devilbliss compressor that delivers 6.8 scfm at 90 PSIG. The compressor regulator is set at 100 PSI, and I am running...
If you take this wrench apart you will find cut outs where the air is pushed through when these Chinese pieces of fie work punched out the medal they left the punched out part in the wheel thus you do not get the torque. I removed the pieces and it functioned OK. Not the best wrench. Sorry quality control usually CH is better about quality.
May 09, 2010 | Campbell Hausfeld Tools & Hardware -...
Runs fine in reverse, but will not run full speed
make sure the power /speed controll is set on high in both directions yes it can easily be rebuilt i can do it cheaper than most places, i have 30 years experience at fixing air tools - i worked for snap on tools also check and see that the front housing screws are equally tight.
Feb 18, 2010 | Ingersoll Air Tools & Compressors
This is an older model FW-20h. The air pressure is 150 psi but does not turn the rotor
go get some wd 40 unless its totally locked up as in you cant turn it by hand, then one or more internal vanes are jammed inside on the rotor
Sep 29, 2009 | Impact Fuji Air Tool Fw-14px-5 Wrench
Sand has entered my CP734 impact wrench.
Check the following website. It is a pdf file, so you will need Acrobat Reader, which is available on this website. After it loads, it lists various CP model numbers on the left side, so scroll down to 734 and click on it( it says 734 OBS) and it will open an exploded view of the breakdown of the CP 734 impact wrench. On the Acrobat toolbar, you can expand the picture as much as you want to and print it.
Good Luck!
Jul 31, 2009 | Chicago Pneumatic 1/2" Air Impact Wrench
1996 Isuzu Trooper Crankshaft bolt is impossible to turn
"Heat" and air impact is the trick. Get it as hot as you can and hit it with air impact. Be careful not to burn yourself!
I hope this helps you, and I wish you luck with your repair.
May 05, 2009 | 1996 Isuzu Trooper
Air Tools & Compressors Logo
213 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
