Question about MSI Computers & Internet
Where is the taskbar button - MSI Computers & Internet
  • 564 Answers
The taskbar is the bar that runs across the bottom of the screen.
Posted on Jan 20, 2013
Putting icons on my taskbar
Very easy to do.
1. click on the window button
2. select all programs
3. right click on the program to pin to the taskbar
4. select more
5. click pin to taskbar
Aug 16, 2016 | HP Computers & Internet
Move taskbar to bottom
Right click on taskbar
Make sure "LOCK THE TASKBAR" is UNchecked.
Left click (and hold left button down) on center of taskbar and drag to bottom center.
Apr 03, 2014 | Computers & Internet
Taskbar not displaying on the desktop
Put the mouse cursor on the bottom of the screen area. When you see the cursor change to the up and down arrow, press and hold left mouse button and drag the taskbar up. Then click right mouse button in taskbar, go to Properties and uncheck auto hide taskbar.
Apr 03, 2014 | ASUS Computers & Internet
To adjust rotating display of laptop ,taskbar with all icons moves on different(bottom to top)
Step 1:
Has your Windows taskbar suddenly moved to the side of your desktop screen or even to the top? This can be very disruptive to your daily computing, which may mean a loss of productivity at work. Your taskbar could have moved because of a glitch in programming or an inadvertent mouse click while you were focused on something else. The latter is more common and is usually the result of an unlocked taskbar.
Older Windows Operating Systems Windows 98, Windows ME, Windows XP and Windows Vista all utilize similar solutions for this problem. For the quickest route to returning the taskbar to the bottom of the screen, first place your mouse pointer over empty space on your taskbar (space not occupied by an icon or a button indicating an open program) and right-click. Look near the bottom of the menu that appears for the "Lock the Taskbar" listing, and make sure there is no check mark next to the listing. If there is a check mark, it means the taskbar is locked and cannot be moved, so click on the listing to deselect (and unlock) it. With your mouse pointer again over an empty space on the taskbar, click and hold the left mouse button and then move the mouse pointer to the bottom of the screen. When you release the left mouse button, your taskbar should have moved. As long as the taskbar is unlocked, you can also vary its height. Hold the mouse pointer over the upper edge of the taskbar until it becomes a double arrow (pointing up and down). Then click and hold while you drag the upper edge of the taskbar to the you desire. Once you have the taskbar where you want it, remember to lock it again by selecting the listing on the right-click taskbar menu.
Another option is to visit the Microsoft Windows website and download and run an automatic "Fix it" program, which should take care of programming issues. Windows 7
There are three options for moving the taskbar in the Windows 7 operating system. The first option involves right-clicking on an empty space in the taskbar and then navigating to the "Properties" menu (look near the center of the menu) to set the location of your taskbar on your screen. This menu also allows you to change or establish a number of other default settings relating to your Start menu and taskbar. The second option is exactly the same as the first process given for the Windows operating systems previously mentioned. And again, to prevent the format you have established from changing, lock the taskbar by right-clicking on an empty space of the taskbar and selecting "Lock the Taskbar" from the menu. The third option is a bit more involved and requires downloading registry files (files ending in ".reg"), saving them to your desktop and then double-clicking on them to merge them with your operating system. The files can be deleted after use.
Microsoft online support
http://support.microsoft.com/kb/253679
Feb 17, 2013 | Dell Inspiron Mini 10 Notebook
Lost start button and icons on my toshiba lap top
Do you mean the taskbar along the bottom of the screen?
If you move your cursor to the bottom of the screen the taskbar should appear. Right click anywhere on the taskbar and click properties. In the properties window, on the taskbar tab, uncheck 'auto hide taskbar'.
Mar 29, 2012 | Toshiba Satellite L655S5158 156Inch Laptop
The start button is found in the upper part of the screen
Your taskbar may have been unlocked and moved to the top of your desktop. I'll continue under that assumption.
  1. Right-click on your taskbar. If checked, un-check 'Lock the Taskbar'. Otherwise, skip to Step 3.
  2. Left-click on your taskbar and drag it to the bottom of your desktop. This is the original position of the taskbar.
  3. Right-click on your taskbar. Check 'Lock the Taskbar'. (OPTIONAL)
Jun 09, 2011 | ASUS LCD Monitor
On my Vista desktop, the start/taskbar shows up on the right side when it used to be along the bottom of the screen. why did it move and how can i get it back to the bottom?
First, right-click the taskbar. If "Lock the Taskbar" has a check mark next to it, the taskbar is locked. You can unlock it by clicking "Lock the Taskbar" again. Then, click an empty space on the taskbar, hold and drag the taskbar to one of the four edges of the desktop. When the taskbar is where you want it, release the mouse button.
Mar 08, 2010 | HP Pavilion dv9000z Notebook
MY TASKBAR HAS MOVED TO TIGHT HAND SIDE OF SCREEN
You should be able to left click and drag it back to the bottom of the screen.
Sep 20, 2009 | Microsoft Windows Vista Home Premium with...
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
My whole taskbar is not visible
If you move the mouse pointer to the very bottom of the screen, the taskbar should pop up as it does when you press the Windows Button, but without Start. If you want to keep it up, right click on the taskbar and select "Properties" In the new window, "Unselect" "Autohide" and the taskbar will stay up.
Jun 11, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
20 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
