Question about Fujitsu Siemens AMILO Pro V2000 Notebook
I deleted my wireless driver
I was removing some unwanted software and i accidently deleted my wirelession which is my wireless driver and i am now only connected to the internet on my lap top via cables can someone help
  • 564 Answers
Try doing a system restore to before you deleted it.
Posted on Jan 20, 2013
  • shyla1
    shyla1 Mar 01, 2013
    How do you do a system restore?
zohail
  • 1223 Answers
SOURCE: fujitsui seamans wireless switch
it should be like tower sign or dish antenna like sign u should know the config of the laptop what are the components if it has wifi then sure there is key for that on keyboard may be on the Function keys
Posted on Feb 20, 2009
babes_ganda0
  • 381 Answers
SOURCE: no internet connection
re-install all network drivers or uninstall all network drivers and install again the drivers
Posted on May 23, 2009
SOURCE: CONNECTING TO WIRELESS INTERNET
thanks
Posted on Sep 24, 2008
etaf
  • 779 Answers
SOURCE: My laptop ( AMILO Pro ,V2010) ,can connect to
This is quite a long reply and may appear very technical - however, have a read through and see what you can do Answer.The following assums that your wireless connection is working and other PCs are able to connect:
There could be quite a lot of reasons you are not getting a connection to the wireless - some common issues
  1. the wireless is switched off
  2. Firewall may be blocking
  3. Remove profile
  4. Check Device working in Device manager
  5. Something else on the PC blocking
so quite a few things to check - so lets start in order
  1. Wireless Switch:- Most laptops have a wireless switch - some use a physical switch, other use a combination of the FN key + one of the F keys to toggle on/off - make sure this is on
  2. Firewall:- The firewall my be blocking access - try to disable the firewall. Often programs like Norton, Mcafee etc, when the subscription runs out can cause issues and need to be uninstalled, to uninstal you may need to use the removal tool available on thier websites. One of the ways to test this, is to do a PING test. Press the "Windows key" {bottom left of the keyboard} and at the same time press the "R key", now in the search box that appears - type "CMD", a black box will now appear on your screen, in that box type the following "ping google.com" if you get 4 replies then you can access the internet and your firewall may well be blocking the access try disabling the firewall.
  3. Remove wireless profiles http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  4. Have a look at device manager Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc and see if you have any ? X or ! look under network adapters - click on the + and see if you have the adapter listed It will have a name something with wireless or 802.11 B/G/N included - check if it has any X or ! or ?
  5. safemode:- Try to boot the PC into "safe mode with networking". To do this switch the PC on and now as it starts keep tapping the F8 key untill a menu appears, from that menu choose "safe mode with networking". If you can now connect to the internet,then there is something blocking your access on the PC when it starts normally - post back a comment and if that's the case, We can try doing a "clean boot" and try to identify the startup or process that is causing the issue
A very useful tool to use for wireless issues is xirrus, http://www.xirrus.com/library/wifitools.php If you can copy the program onto the PC thats not working and install and run, this test if your adapter is working and also will display all the networks broadcasting in your area. Which will prove the hardware works.
If this solutions solves you problem, please do not forget to rate my solution. If not, then please comment back so I can help some more
Posted on Apr 09, 2010
PaulusPC
  • 53 Answers
SOURCE: laptop fujitsu-siemens S7020D, updated software
Do a windows update to recover a more up to date driver for the wireless. If not go to Fujitsu's website and download a windows 7 up to date wireless network driver
Posted on May 23, 2011
Can not find wireless
1) Boot into BIOS to check if you have accidentally turned wifi function off.
2) Check if you have deactivated your wifi (by accident), because you pressed the switch which turns the wifi off (or Fnc+ F...).
3) download the latest wireless driver (use a free driver updater software which will do the trick for you... I have been using slimdrivers free, but there are a lot more out there...)
Jan 26, 2014 | Dell Computers & Internet
Slow internet, not loading fast enough
Is your wireless Secured by a password? Unplug the wireless,and Modem, remove battery, if applicable, check all connections, cables, replace battery, plug in modem, allow it to selftset, plug in wireless, allow to selftest, reboot computer. if no change, contact ISP for testing. Most likely it's not your wireless it's your computer and specificly your broswer. I don;t know waht your computer is or what OS you are using , so Try these tips, choose your OS : http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 OR : http://www.pcworld.com/article/143538/windows_vista.html OR http://www.wikihow.com/Speed-up-a-Windows-XP-Computer. Delete ALL TOOLBARS, in Manage Add-ons , remove, disable, ALL unnessary TOOLBARS, Skype, Chat,etc. In Search Providers remove all but Google. I suppest Downloading MALWAREBYTES freeware at :http://www.filehippo.com/download_malwarebytes_anti_malware/. UNCHECK the TRIAL PRO version, you wat the freeware. Run a FULL SCAN, DELETE ALL RESULTS. ALSO, another freeware program CCLEANER at : http://www.filehippo.com/download_ccleaner/. This will clean the junk from your system , also in the STARTUP section, disable ALL unnessary startup programs. Run a FULL SCAN with your UP-TO-DATE Anti Virus, REBOOT THE Machine.
Dec 24, 2012 | 2wire (2701HG-B) Wireless Router
My hp laptop shows "windows
This is a wireless network type driver that appears with Vista. Possibly downloaded as part of a windows update. Most direct solution, is to go to HP website, download the correct wireless drivers for the card in your laptop.
Uninstall the wireless network drivers currently installed ( not the lan ethernet ones, just the wireless ones) and reinstall the ones you just downloaded.
I also found this ( vistaheads website )
"Just delete the profile Windows has for your wifi and reconnect. On Vista go to Network &
Sharing / Manage Wireless Networks, click on "your" wifi and then click
Remove. When you reconnect you'll have to authenticate again but it
should be fine afterwards."
Which is another method
Jul 24, 2011 | Microsoft Computers & Internet
I was working perfectly with wireless connection.Decided to add/remove some programs.Since then the wireless connection is there but internet explorer just shows it cannot open the page.I get the idea i,...
Probably the easiest solution for you would be to do a system restore to the date just prior to your removal of the software. Open the Start Menu and navigate to System Restore. Let it work its magic. Once done, your PC will likely reboot. You should now be able to use it as it were.
Regards, Chris
Jun 29, 2011 | Computers & Internet
Trying to connect my netbook to the internet
Computer side 1) Make sure your netbook wireless drivers areworking/updated 2) Deleted the unwanted / unnecessary hardwaredrivers inside your PC a. Go System Properties > Advanced >Environment Variable b. Add this inside system variable "devmgr_show_nonpresent_devices"-value 1 c. Restart your PC d. Go System Properties > Device manager >View > Show hidden Devices e. Delete those device items with the "faked" icons Network Side 1) Go to wireless setting inside your router 2) Under advance setting/ wireless setting Change the a. DTIM Interval: 1 b. Fragmentation Threshold: 2306 c. RTS Threshold: 2307 d. Beacon Interval: 50 See if the network connectivity is better Happy Troubleshooting
Mar 10, 2011 | Sylvania G-Netbook
I want to downgrade my intel pro/wireless 3945ABG v 12.4.0.21 to v 10.5.1.72 or 10.5.1.75. how to do that?
You will have to remove the driver & softwares from your operating system first.
To remove softwares... Go to Control Panel > Add Remove Softwares > Select Intel Pro/Wireless and choose remove.
To remove drivers... Right click on my computer > Go to Properties > Hardware > Device Manager > Select Wireless Network Adapter > right click on it & select Uninstall
Then Restart your system & begin with the downgrade version of drivers you have.
Enjoy
May 08, 2010 | Intel PRO/Wireless 3945ABG Network...
I got a virus and tried to remove it myself and in the process turned something off or deleted something and my virus was gone... however, my wireless network no longer works and says that i need to...
check into your control panel and look and your list of installed software for your wireless if still installed if not try to re-install your wireless software. and when you use your wireless adapter check if you enabled your wireless adapter. i mean the swith for turning on your wireless...... if not look your the button of that adapter and turn it on
Oct 08, 2009 | Dell XPS M1210 Notebook
How to stop unwanted messages?
Contact your wireless carrier for restriction services or you can change your device's number to prevent unwanted txt messages. Sometimes ignoring the text messages and deleting them, help for future hassle.
Mar 13, 2009 | Cell Phones
Networking
Ok, have everthing as normal IE: devices useable. Then.... Go to Add/Remove Programs & remove any related software.. if optioned, choose "Complete uninstall" Ok, then go to "Device Manager" right click the relevent "Adapter" and UNINSTALL DRIVER. When asked if ya want to remove "Completely" answer "Yes"... This should be OK at this point.
Aug 31, 2007 | Hawking Wireless-G HWR54G (603992506064)...
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
191 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
