Question about Hitachi HDE721010SLA330 1 TB SATA II Hard Drive
HDE721010SLA330 slave Hitachi HDE721010SLA330 slave conficuration
Driver
my phone has been locked and i lost my password so please help me to unlock it or any trick or tip please
Jun 14, 2013 | Hitachi HDE721010SLA330 1 TB SATA II Hard...
Drive has a hardware problem that can't be repaired
See if the drive is still under warranty and if so replace it.
If you need data recovery consider an online data recovery service like http://FreeDataRecovery.us
Sep 11, 2012 | Hitachi HDE721010SLA330 1 TB SATA II Hard...
How to set jumpers on a hitachi hard drive
Use the above diagram to set the HDD in the required mode.
For more details on Master and Slave modes please use the below link
http://www.ehow.com/how_6031_change-master-slave-designation.html
Aug 18, 2011 | Computers & Internet
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
How to install hitachi cdr-7930 on my dell dimension 4100 window xp home edition it doesent computer fails to boot with it hooked up
If this is a IDE drive...You may have the data cable connected the wrong way around. Do you only have one hard drive installed..? If you have and you are connecting this drive on the same data cable as your hard drive, you need to set the hard drive to "slave present" or "Master" and the dvd drive to "slave" If this is a SATA drive, you do not need to do this and you may have a faulty drive.. On the rear panel of the drives (where the cables plug in) is a jumper pin. Now either marked on the case or even on the drive label are the meaning of these pins. There are usually four sets of two pins laid out vertically. You need to put the little black jumper onto the pins marked "slave" on the dvd drive and "slave present" or "Master" on the hard drive if they are both on the same data cable. you can also set both drives to "cable select" but you then have to use the correct connector on the data cable for each drive. try the slave and master settings first, if you have no luck, message me again..
Dec 30, 2009 | Hitachi (CDR7930) Internal 8x CD-ROM Drive
I want to install a Hitachi Deskstar drive and the
Based on normal configurations, you should make sure that the pin settings on your main boot drive is set to master, and then make sure that your Deskstar is set to slave. If that doesn't work, then you might have a Bios setup issue. Let me know.
Thanks
Mark
Dec 18, 2009 | Intel D915GAG Socket 775 Motherboard -...
Windows 7 on slave drive, can I format master now?
in your bios can you tell it what drive to boot from first. sorry for the lame question but im thinking its going to the defualt drive each time.
Nov 30, 2009 | Microsoft Windows XP Professional
Slave jumper settings for a 2.5 Hitachi DK23DA-20F hard drive
Most hard drives I've come across have tiny little letters on the PCB next to the jumpers that say MA SL CS which are for master, slave, and cable select. If that doesn't work, go to Hitachi's website and search their support section. There is a diagram of the jumpers for that drive out there somewhere. Good luck!
Nov 07, 2009 | Hitachi (DK23DA-20F) 20 GB Hard Drive
Baught a Hitachi HDP725032GLAT80 hard drive. Installed it as a slave drive in my existing PC ... The PC says it's installed and working correctly, but I cannot see it in Windows Explorer??? Have I missed...
Did you format it? The PC won't recognize it until it's formatted, which you can do via Control Panel - Administrative Tools - Computer Management, then click on Disk Management on the left side. You'll see the drive, and have the option to format it right from there.
That's the first thing to check. Let me know if you've already done that and it's still not being recognized.
Jul 26, 2008 | Hitachi Computers & Internet
Hitachi HDE721010SLA330 1 TB SATA II Hard Drive Logo
56 people viewed this question
Top Hitachi Computers & Internet Experts
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
