Question about Frigidaire GLTF2940ES Front Load Washer
How to run a diagnostic test on model GLTF2940FS2
How do I run diagnostic test
Washing Machine Diagnostic Test & Error Codes (Cabrio ...
? 1:29
https://www.youtube.com/watch?v=yoCTzbl4FPs
Nov 22, 2010 - Uploaded by applianceassistant
Washing Machine Diagnostic Test & Error Codes (Cabrio, Bravo, ..... What can i do? ... I tried to put it in ...
Fix and Diagnose Kenmore Oasis / Whirlpool Duet hE Washer
? 7:21
https://www.youtube.com/watch?v=8Z1JdsJYa14
Apr 24, 2011 - Uploaded by Alprazolam
Tried to do the diagnostic test and it still won't do anything. ... If the latter, and it won't run any diagnostics ...
How do you do a diagnostic test for a Whirlpool Cab
Dec 02, 2015 | Washing Machines
Tip
BlackBerry Tour: How to find your IP address
Like most devices that connect to a network or to the Internet, your BlackBerry Tour has its own IP address. If you need to find your IP address (or if you're just curious) follow the steps below. (The process may vary for other BlackBerry models, but it should be similar.)
A. From the main screen, press the BlackBerry button (the one with seven dots) to go to your Home folder.
B. Find the Options folder (with the wrench icon) and select it.
C. In the list of options, scroll down to Mobile Network and click the trackball.
D. Press the BlackBerry button.
E. Click on Tools on the menu.
F. Click on Ping.
When the Ping test utility opens, you'll see your IP address displayed at the top of the screen, labeled "Device IP." You don't have to use the Ping utility; you can click the back arrow to exit out after noting your IP address.
Alternatively, you can run the Diagnostics Test, which will also display your IP address. To run the Diagnostics Test, follow the steps above, but after step D, substitute the following procedure:
E. Select Diagnostics Test from the menu.
F. Press the BlackBerry button.
G. Select Run.
The Diagnostics Test can take a few minutes to complete, and it will display various settings for your BlackBerry, including the IP address (Device IP). The report generated by the Diagnostics Test will be saved so you can view it later for reference or use it to compare current settings.
on Aug 26, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Code e62 on frigidaire gallery series model GLTF2940FS2
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire GLTF2940F Front Load Washer
Spot screen
Hello
First find an external monitor to test if its the screen on your laptop or the graphics chip in your laptop. If you have an external monitor then hook it up to your laptop and toggle the video over to see if you still see the spot.If it only shows on the laptop screen the Replace the screen.
Another thing you can do is run the built in Diagnostics
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen.
Dec 18, 2013 | Dell Vostro Computers & Internet
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Internal hdd hard error
Using the F12 Diagnostics
Nov 19, 2013 | Dell Latitude D610 Laptop Computer -...
How to clean drain pump frigidaire front loading washer gltf2940fs2
Remove the bottom access panel by removing the almost two hidden screws along the bottom. The pump is located on the right. Remove the two hoses and two screw that mount the pump to the base. Clean away. Reattach hoses and screws. TEST unit with panel off to check for leaks. The hoses can be a pain to get on right. Also beware water caught in tub and drain hose will leak out. Bring towels. Lots.
Sep 28, 2011 | Frigidaire ATF6000ES Front Load Washer
I can't hear sounds through my speakers,why?
This model has a Diagnostics utility which is a hardware diagnostic program placed in the utility partition on the hard drive. The diagnostic utility is also available on the Dell Resource CD.
  • Express Test - Performs a quick test of devices. This test typically takes 10 to 20 minutes and requires no interaction on your part. Run Express Test first to increase the possibility of tracing the problem quickly.
  • Extended Test - Performs a thorough check of devices. This test typically takes an hour or more and requires you to answer questions periodically.
  • Custom Test - Tests a specific device. You can customize the tests you want to run.(You can select the audio test here. If this passes then you have a software driver issue).
  • Symptom Tree - Lists the most common symptoms encountered and allows you to select a test based on the symptom of the problem you are having.
  • To start the Dell diagnostics follow the next steps.
  • Turn on or restart the computer.
  • When the Dell logo appears, press immediately. If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop, and then shut down the computer and try again.
  • When the boot device list appears, highlight Boot to Utility Partition and press .
  • When the Dell Diagnostics main menu appears, select the test you want to run.
  • If all tests pass then you probably have a software issue not hardware.
Sep 03, 2011 | Dell Vostro 320 Desktop Computer
GLTF2940FS2 Ok no timer switch on this model. The spin cycle will not engage. The drain has been cleaned the pump is ok , wash cycle ok , drain ok , when spin time comes nothing. Test rutine , on...
Check with your appliance parts repair people in your area.
You should find no one will touch the electronic control panel. Usually, the time it takes and the cost for diagnostics will negate any profit for the business.
Same as why many cars must go back to the dealer for electronics. Most of your local repair people will just replace the board.
God bless your efforts.
Jul 07, 2017 | Frigidaire GLTF2940F Front Load Washer
Hi buddy, can you give me a hand here: i have a dell inspiron 1545 model notebook with vista OS installed. when i turn it on it goes straight on to the bios set up. can you give a help on these issue?...
  1. Check for a stuck F2 key (That prompts system setup)
  2. From a power off State, press Fn+Power and run diagnostics on the system, after the PSA diagnostics, press N to not complete the memory diags, go to the Dell diagnostics, Customer, keyboard test and test the keyboard, then run the HDD diagnostc there too.
Feb 19, 2010 | Dell Inspiron 1525 Notebook
Frigidaire GLTF2940ES Front Load Washer Logo
142 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
