Question about Canon imageRUNNER C3200 Copier
Location of IH Power supply/ canon ir 5570
spinal
  • 287 Answers
SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Posted on Apr 20, 2008
hquiteculo
  • 19 Answers
SOURCE: Error code E000025-00001
there is a toner feed motor over currente detection error, there is a toner botle motor connection detection error.
1- check the connector for any fault in connection.
2- replace the motor
Posted on Apr 09, 2009
Cogz
  • 1326 Answers
SOURCE: Need to locate the waste toner container on a Canon ir 6800
The waste toner bottle should be on the right side of the copier toward the rear of the copier. It is behind a pannel that is held in with 2 screws. Take the screw out & open the pannel & the bottel should be inside that opening it is a milky white container. Pull it out, it is rather large. When you dump out the toner make sure you have a plastic bag with No holes in it, it can be very messy if you are not carefull......Good Luck
Posted on May 21, 2009
  • 118 Answers
SOURCE: Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Posted on Jul 16, 2009
  • 149 Answers
SOURCE: Need to change password on IR 5570 Address
there is a possiblitly that you can clear the passwords for the copier in service mode..... but weather it will remove the password for a mail box or not i can not say.
what you need to do to get into service mode is
hit the additional functions button....
then the 2&8 at the same time .
then the additional functions button again
this should bring up service mode
now you push the copier tab
then functions tab
then the clear tab
under the clear tab you will pwd clr try hitting it and click ok
hopefully that will clear the passwords but i can't make any promise's if it works for the address book
Posted on Jun 10, 2010
I DONT NO THE IH POWER SUPPLY
The IH power supply is located below the operational panel behind the front cover below the op panel,
Sep 23, 2015 | Konica Minolta Bizhub C552 Copier
Ir 6570 error code e0004 e00103
E004-0103 The IH power supply is faulty/the IH control mechanism is faulty. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
The IH current is faulty. (no current) - Check the connector for any fault in connection. - Replace the fixing heater power supply. - Replace the DC controller PCB.
This link also offers a down loadable pdf service manual.http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR6570
Apr 15, 2015 | Office Equipment & Supplies
Canon ir 5570 e0004-0010
Try pressing Additional Functions then 2 and 8 simultaneously then Additional Functions again. Select Copier > Function > Clear > Err press ok. If the problem persists it will need parts. Error means that there is a problem with the IH power supply.
May 01, 2012 | Canon imageRUNNER 5570 Copier
IR 6570 Error occurs E804-002
This is an error for the DC power supply fan - there is an IH power supply cooling fan error. The book I have doesn't give the 002 part of the error but check that
Jun 21, 2011 | Canon imageRUNNER 5570 Copier
Im have trouble ir 5570 code eror e821
hallooo ... sp,
what's the difference with the IR5570 IR 6570 .. thanks
Nov 30, 2010 | Canon imageRUNNER 5570 Copier
6570 - e804-0001
E824 There is a primary charging cooling fan error.
0001 The primary charging cooling fan stop signal has
been detected for 5 sec or more even when the
primary charging cooling fan is on.
Service manual says:
- Check the connection of the connector.
- Replace the fan.
Why did you changed power supply? Did you try with new dc controller?
Jun 29, 2010 | Canon imageRUNNER 5570 Copier
E804-0001 in 6570
did you check to see if the maybe it was the dc power supply fan(fm6) that has burned out and is causing the ih power supply fan(fm7) to act up. one could cause the other to go bad..... also believe it or not the DC controller controls all fan functions so maybe one of the fuses on the dc controller could have blown out as a result of the inital fan going bad. that is where i would go with this next.. check continuity in all the fuses on the dc controller to make sure they are all intact...
if you have any problems or need any help please call me
Jun 12, 2010 | Canon imageRUNNER 5570 Copier
Error message: E000004-0401
Probably the copier is iR C5185i
- E004 = Fixing unit protection circuit trouble
-  0401 = Check the connection of the connectors of the relay PCB, the IH power supply, the fixing thermoswitch, and replace the fixing unit (fixing
thermoswitch OFF), the relay PCB, and the IH power PCB (blowout of the
FU261).
In the service mode, clear the error by selecting COPIER > FUNCTION >
CLEAR > ERR.
You need a canon technician to resolve this problem.
Sep 25, 2009 | Canon Office Equipment & Supplies
Canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
May 15, 2008 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER C3200 Copier Logo
56 people viewed this question
old marine
old marine
