Question about Philips Televison & Video
What panel display will fit philips 47pfl3603d/f7
  • Philips Master
  • 933 Answers
According to research, you set uses a LC470WUE-SAA1. I would suggest you double check by removing the back cover of the set. On the back of the LCD panel, there should be a white sticker that states the LCD panel model #
Posted on Jan 22, 2013
5 Suggested Answers
proton77
  • 1183 Answers
SOURCE: need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Posted on Jan 03, 2009
  • 336 Answers
SOURCE: i can't get my philips
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Posted on Jul 26, 2009
jhinsincity
  • 616 Answers
SOURCE: the model no. is 47PFL3603D/F7 flat panel lcd tv
Manual RETREVO.COM
Posted on Jan 01, 2010
jhinsincity
  • 616 Answers
SOURCE: I am looking for all
Best thing to do is contact a local tv shop, some fuses are specialized so its best to be sure you are getting the correct values. we sell them for a couple of dollars each.
Posted on Oct 30, 2010
What size are the table top mounting bolts for a philips 47pfl3603d/f7 tv?
The size of the mounting bolds are M8x ...., where .... = 12mm inside the TV and xxx mm outside depending of the thickness of the bracket. 30bd4761-3c8f-44f5-b84e-adf07806dc82.jpg
Jun 02, 2014 | Philips 47PFL7403D 47 in. LCD TV
47" philips lcd tv goes black but still has sound
Yeah the picture tube is old.... if it's a lcd or led then u're having prob's with display Circuits... call a techie and he'll fix it
Jan 11, 2014 | Philips 47PFL3603D/F7 LCD HDTV, 47...
Philips remote control not working
have the remote tested, any repair shop can do this and usually for free.
If remote is good the receiver in the set is likely bad.
Nov 27, 2012 | Philips 47PFL3603D/F7 LCD HDTV, 47...
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
Philips 47-Inch 1080p LCD HDTV - model 47PFL3603D - worked great until we tried to move it - it was bumped very lightly, and the picture now only shows 1/2 the screen
There are two ribbon cables at the top centre of the display, if one is loose, you will only have half a screen. When taking a small bump the cable has become loose. Check the ribbon cables and connections.
Jan 11, 2011 | Philips 47PFL3603D LCD TV
I am looking for all replacement fuses in for the 47" model, model # 47PFL3603D/F7
Oct 30, 2010 | Philips 47PFL3603D LCD TV
How do you fix the screen on a Philips tv model number 47PFL3603D
If the display is damaged, you can't. If it just has scratches then you should be able to live with that. If it's damaged to the point of the picture is distorted with lines then its time for a new set if that's what you choose, because the display is about as much as a new set.
Oct 20, 2009 | Philips 47PFL3603D LCD TV
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
May 29, 2009 | Philips 47PFL3603D LCD TV
Televison & Video Logo
51 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
