Question about Eureka 5893AVZ Bagless Upright Cyclonic Vacuum
Eureka 5893 roller does not spin
The roller does not spin but it has suction in the hose
  • Eureka Master
  • 18,394 Answers
Check the belt on the brushbar is not broke click the link below for the manual ,that will give you full instructions how to replace it ,,,,,,,,,
http://www.eureka.com/FileLibrary/d9d3256193114e4a96be2cf719fd5bed/74227.pdf
Posted on Jan 20, 2013
reddevil6
  • 1673 Answers
SOURCE: Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Posted on Jan 22, 2008
reddevil6
  • 1673 Answers
SOURCE: How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
Posted on Jan 29, 2008
reddevil6
  • 1673 Answers
SOURCE: low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
Posted on May 15, 2008
  • 10865 Answers
SOURCE: the suction on my eureka optima stopped working
Hi there. Most suction problems are due to a blockage. Start with the base and look carefully for debris that is stopping air flow. You may have to remove the base plate to get to the problem. I am including a link to the manual for your machine. look on page four so see how to remove the base and check for blocked airways. http://www.eureka.com/service/manuals/75287_eng.pdf
Posted on Aug 19, 2009
nwj2468
  • 76 Answers
SOURCE: new Eureka 5893 BVZ looses suction
eureka is about the most helpless website ever!!! did u try cleaning the filters?
Posted on Aug 22, 2009
Hi I have a Eureka upright bagless vacuum and I need to use the hose attachment to vaccum a car seat and floor. How do I get the suction to apply to the hose only?
Look at the top of the plastic housing that covers the brush roller. You will find an adjustment lever that switches from floor to hose. The lever may be difficult to move. It is not a feature of Eurekas that ages well.
Feb 01, 2017 | Eureka Vacuums
Can't get the roller to spin
i suggest taking hose off and declogging it by using a water hose to make sure its free of debris. Plus check your belt first take off bottom plate the you'll be able to tell if belt is broken which it sounds like it is.
if belt is good and hose is clear and still brush wont spin then your brush motor needs replacing. hope this helps.
Mar 05, 2013 | Eureka Whirlwind Litespeed 5740 Bagless...
Eureka vaccuum blowing out and not sucking in
Hi There,
I am going to assume you are talking about a Eureka upright vacuum.
The cause for this is generally either
A) Broken Belt - Which you can easily fix by changing belt
or
B) Blockage in the hose somewhere - Basically test the suction with the machine turned on with you attachment hose and see if you have suction. If you do check the belt and make sure you clear out any muck left around the roller.
If you need Eureka vacuum belts go to VacuumSpot.com.au
May 13, 2012 | Vacuums
Does not suction/pick up trash and debris.
we have an eureka 4495 model and it doesnt want to pick up the dirt off the floor but the hoses are clean and the hose it self has suction and the roller and belt are ok and turn
Feb 02, 2011 | Eureka True Clean Upright Vacuum (Yellow)...
No suction when vacuuming, but suction is good when using hose
check for blockage from where the hose sets in its
holder to the roller brush. Also see if the brush is
turning, the belt maybe broken.
Tom
Oct 22, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
New Eureka 5893 BVZ looses suction
Jul 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka 5893AVZ Bagless Upright Cyclonic Vacuum Logo
146 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
