Question about Dell Inspiron 1300 Notebook
I CANT CHANGE THE REGION ON MY DVD, although I have 1 change left
I changed my region code the other day to watch a foreign film, but was aware that i had another change left so would be able to change it back. But now I insert the region 2 disk (my home region), and WMPlayer (or the Dell Cineplayer) won't play it. It says:
1.'Your system is set to region 1. To play this DVD , set your system to region 2, 4 or 5'. - I click OK and change the region to Region 2 (UK)
2. The computer warns me that 'This is your last chance to change the region setting on your DVD. Are you sure you want to proceed?' - I click yes.
3. Then an error message pops up saying 'Unable to update region setting. Please make sure the drive contains a region 2 media and you have administration privilege'. I click OK as there is no other option.
--The problem is that I changed it before and no one else has an account on my computer so I must have administration privilege . Apparently I also have 1 change left, and I am inserting a region 2 disk. So why won't it let me change back to my real region? And how could I fix it?
Thanks
  • littlemai Jan 26, 2009
    Thanks Ramesh. I put in a dvd which only works in Region 2 (rather than working in multiple regions) and it changed back! Hurrah!
  • nakedlunch02 May 11, 2010
    I don't think this is about administrative
    privileges, it's about having exceeded the number of times you can reset the
    region code on your drive.
    And to my knowledge there's no known legal way to circumvent
    it with that single drive. problem is some older dive only allowed 2 region changes,and newer ones allowed up to 5, can you recall how many times you have changed the region? Simply it would most likely be cheaper to install a second, or external DVD drive.
    Novelist:
  • 126 Answers
Try using a software called DVD Shrink to watch your DVDs on. But check if its legal to use in your respective areas.
You can see how many changes you have remaining by doing this.
"Right Click" on "My Computer" and select "Manage".
Select "Device Manager", expand your "DVD/CD-ROM drives", "Right Click" the drive model and select "Properties" and select tab called "DVD Region".
This will show you how many "Changes Remaining" you have and give you the ability to change the region (so long as you have available changes left).
Read this
http://www.microsoft.com/whdc/archive/dvdregion.mspx
Some manufacturers fix a region code in the windows registry.
Also you may be able to upgrade your firmware
of your dvd drive. (it may or may not start region count again but worth a try if nothing else will work.)
also u cna try this
it is that now that it is fixed, it is fixed for good unless you "flash" the drive's frimware. Check out http://www.vcdhelp.com for extra firmware for some drives. OR
Try putting in a dvd which is not made for multiple formats (i.e. Region 1, 2, 3 etc.), for e.g. I put in a Australian comedy disc which is only made for region 4, it enabled me to change back to that region. Hope this helps. If you are having trouble finding whether a disc supports multiple regions just try experimenting with a dvd which you might think is local to your country.
or try this out ....
you have to insert the DVD you're trying to play first, then try and change the region. It this might work.
Hope that helps!
or check this out
To change the region code, you must use a DVD disc that supports CSS
(Content Scrambling System).
look here:
_http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4QEKVZ
Posted on Jan 26, 2009
  • ramesh singh
    ramesh singh Jan 27, 2009
    the best thing what i can suggest u is that simply go ahead and change the cd/dvd-rom or what u can try is that reinstall the operating system...and then replace the cd Rom...good luck
  • 520 Answers
You can flash the drive with region free firmware (best option if you know what youre doing)
you can reinstall os giving you extra tries.
or you can use a program called any dvd(free)which enable you to watch any region (safe)
flash is best if youre not sure or cant find software let me know and give your dvd details(firmware)
eg freecom dvdrw 523252
2 Suggested Answers
  • 3940 Answers
SOURCE: Changing the DVD Region code
Legally, the only way to resolve your issue is a new drive, the region code in the drive has been locked in the firmware and cannot be changed by normal means (You can search google for DVD region Code Cracks, but it is not recommended no legal)
Antipiracy laws mandated a limit to the number of times the Region code can be changed (5) and if you are going to be playing a lot of media from different regions, then get another drive and set it to one region (and mark the region on the drive) and use this for the other
I bought 3 disney movies from the us can'play them on my dvd need a code area australian
Of course I cannot condone any solution contrary to any Australian, US, or international law.
Most DVD players offer the option to change the region code...
Please be aware that due to DVD piracy problems, every DVD player manufactured, regardless of who makes it or where it is made, allows a maximum (if at all) of THREE region code changes.
In your circumstance, this would mean that you can change your DVD player region code to region 1 (US), watch your videos, and then change it back to the AU region code...You would then be allowed one more change. If you attempt to change the region code after that, your DVD player would lock out and be turned into a paperweight.
As a "Yank" who has been to Australia (Perth NSW- twice!) I sympathize with your problem- wanting to have these videos forever and not being able to watch them at all....
The only "safe" option that I can offer is to surf the web for a program called DVD-Shrink, or something similar that will allow you to remove the region code from your DVD's, and set it to "region zero"...which will play the DVD anyplace, anytime. DVD-Shrink works as a copy program from a PC DVDR drive and can remove most region codes from a DVD depending on the disc- most is explained in the FAQ.
Please do not allow yourself to be duped into trying an "all regions" download for your DVD PLAYER. Every single one that I have received a reply about, after warning off the "customer" has resulted in a "my player does not work anymore" response!
Mar 02, 2011 | Televison & Video
I need to unlock a Toshiba DVD player/VCR Combo SDV395 to view DVDs' purchased in Francs
You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
Nov 02, 2010 | Toshiba SDV395 DVD Player/VCR
Message "wrong Region" appears in my Sony DVD -
DVD region is an anti-piracy method to block DVDs from other countrys to be played on a region where that DVD isn't available for selling. You still can watch that DVD by changing the DVD Player region code from options but be aware that you have a limited number of changes, after changes reach 0 you cannot change DVD region code anymore and your DVD player will be stucked to a certain region that you selected.
Nov 02, 2010 | Sony DVPFX810 Portable DVD Player
My compaq laptop says i cant change the region
You only can change this setting 5 times, then it is locked. You can not change the Region code after this even if you reinstall Windows, or move the drive to another computer. You can try upgrading the Firmware for the drive from the Compaq / HP Support page for your product. If that does not work, you will need to replace the drive, or download and install a Region Free software like AnyDVD or DVD Region Killer.
Jan 09, 2010 | Compaq (158165-001) DVD Drive
I bought a movie diff region and i have a dvp1013 canregionchange
DVD's are made in different region codes as they are intended to be played on specific types of DVD players. As far as I am aware there is no way to change the region code of a DVD.
However, your DVD player maybe able to bypass the region code through a type of "hack"; you might search online for your specific DVD player.
A DVD drive on your computer may also be able to play the DVD although you may need to further research specific software players. You should be able to find some freeware that would enable you to play your DVD on your computer assuming your drive can read DVD's.
Another option is to buy a region-free (also known as an all-region) DVD player. Although they are a bit more expensive than a regular DVD player, region-free means you never have to worry about software fixes or trying to reconfigure your current DVD player. Online sellers abound the most well known probably including Amazon and YesAsia (a site that specializes to selling Asian merchandise overseas).
Hope this helps, I was a little vague in places.
Basically you can't change the DVD so much as the DVD player.
Jun 26, 2009 | Philips Televison & Video
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
The first solution is free VideoLAN player: click here to download VideoLAN.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition Click Start Player button, and try to play your DVD
Finally Load another firmware for your DVD drive which disables the region code protection.
Jan 26, 2009 | Microsoft Windows XP Professional for PC
Jan 26, 2009 | Dell Inspiron 1300 Notebook
Dvd stuck on zone 1 when i am a zone 4
MMM impossible to unlock Yes it is inside your own time and mind set thats true for you !Anyway Region zoning does not protect copyright.!Newzealand is A Region Free regional code Free
country.
so ridiculous restrictive practices that are coming to be regarded as
"normal".Thats what I would like to have you gies with this site to do to help !
stop this .
I know how to hack .to change the zones Any way.I have never recorded NEW
RELEASE ONES!
1. Empty the Disc Drawer
2. Press "Setup" on the remote
3. Press 1, 3, 6, 9, Left, Left, Left, Right (keypad)
4. "Version" will appear on the Menu, scroll down to this.
5. Once in "Version" go to "Region" and go across to the number and change
to "0" to Multi Region. Use the keypad to change the zones.
6. Then exit Version
7. Then exit Setup
THATS HOW I DID THE IMPOSIBLE I DONT KNOW WHAT THAT IS. I HAVE AN IQ OF 184 AND Having Aspergers Helps . I know about blue book 2012 and want to hack the Air force bace .Please reply.
Feb 12, 2008 | Computers & Internet
Region codes for philips dvd 722
on these dvd players you can only change your regions 1 ,2 or 3 times and then they wont change any more. sorry I couldnt help
Jan 07, 2008 | Philips 30DV693R 30 in. TV/DVD Combo
Dell Inspiron 1300 Notebook Logo
1,909 people viewed this question
Alun Cox
