Question about HP Pavilion dv1000 Notebook
HP Pavilion dv1000 screen has gone extremely dim. VGA Monitor shows fine.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • HP Expert
  • 146 Answers
Replace inverter HP Pavilion dv1000 screen has gone extremely dim.  - f08e3c39-ee23-40ba-86f2-f7dcab1bd045.jpg
Posted on Apr 13, 2014
3 Suggested Answers
Slasher_X
  • 767 Answers
SOURCE: hp pavilion dv1000 screen is extremely dim.
I'd have to say that your laptop's backlighting isn't working, but judging by the fact that the external monitor didn't work either it seems that your laptop's GPU is malfunctioning. It can be replaced but they are extreamly hard to find. I suggest taking this laptop to a technician and letting them give you a practical look to see if it's worth fixing.
Posted on Jul 05, 2011
Vincent Von
  • 152 Answers
SOURCE: HP Pavilion dv1000 screen has gone extremely dim.
Two things: video card issue or video card settings. Try to go to the power options configuration of your portable system. Adjust the brightness. If changes does not take effect on your portable's display as well as the external monitor, it is a video card issue. The last option of resolution is to re-install the video driver. Click the link below and choose the exact model of your computer. Try to download the video driver for your computer. Make sure that you have the correct driver for your operating system. If re-installing the video driver still fails, unfortunately you need to have your video card replaced. Usually the video card comes embedded on the motherboard. That means you have to have your whole board replaced.
HP Pavilion Models
HP Pavilion dv1000 screen has gone extremely dim. changed the inverter and nothing. connected to an external monitor and nothing. what is wrong? HELP PLEASE!
HP Pavilion Models
Jul 05, 2011 | HP Pavilion dv1000 Notebook
I have a HP DV4 Pavilion 1287cl laptop and the screen has gone white. When I hook it up to an external monitor it works. Any ideas? A tech friend tested the inverter and said its fine.
I've come across this a few times and almost always with an HP. It was always the video card. I can't help too much more without seeing it. My best advice would be to take it to a repair shop.
hope this helps
Apr 17, 2011 | HP Pavilion dv4000 Notebook
The display on my HP Pavillion dv1000 is extremely dim and I can't get the screen to lighten so I can read it. I have done a hard reset and replaced the power inverter. It blink on once, but that was the...
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 04, 2010 | HP Pavilion dv1000 Notebook
HP DV1000 screen too dim
The 4 most common problems with dim lcd's on a laptop are boken screens, bad power inverter, bad florescent bulbs or a broken cable.
You can test the power inverter with a meter.
There should be 2 bulbs. If your screen is dim and your inverter is good and you can still make out what is on the screen, you probably have a bad bulb. If you can't determine which bulb is bad you'll have to replace both.
In my opinion, the easiest way to handle this is to replace the whole screen. Yes, it's more exspensive, but consider that it is most likely to fix your problem. A replacement screen comes with the power inverter, both bulbs, and the cable; already assembled and ready to install.
Mar 06, 2010 | HP Pavilion dv1000 Notebook
Hp dv1000 no backlight, repalced inverter, still no screen
plug in a monitor in the side of the laptop if it shows up then the lcd is bad. Also try and reset the memory by pulling it out and then put it back in if not in all the wall nothing will appear on the LCD.
Jan 15, 2010 | HP Pavilion dv1000 Notebook
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook PC display not coming on
Does the laptop power up even though you can't see an image on the screen?
Connect an external monitor to your laptop and powe it up, if you see the normal Windows images then the laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 22, 2009 | HP Pavilion dv6000t Notebook
Adding multiple monitors from my HP pavilion
you have an ext monitor connection which you can use another monitor or get s-video lead and connect to a tv.
use fn + f4(or f key that has little square icon printed on it)
this combination switches from laptop screen to ext screen/tv
Jan 28, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
