Question about Craftsman 13953637SRT Remote is Equivalent to the 81LM
Garage door trolley is stuck against down bolts and will not release.
When pressing remote, there is a short electrical hum, but the door fails to move. Up or down.
Sounds like the opener has opened to far and the trolley is now jammed against the stop bolt.
May 24, 2015 | liftmaster Garage Door 1/2 Hp
The garage door hums for a few seconds and then stops, the door won't go up or down.
Make sure the trolley isn't jammed against the bolt just in front of the motor.
Oct 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
My 1/3 hp craftsmen door opener just hums when you hit the wall button or remotes in the car. I replaced the starter motor capacitor and nothing changed any ideas?
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain until the tension is removed from the trolley. Run the motor until the door is closed. While the door is closed locate the 'up limit' adjustment on the side of the motor unit and turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am having a problem with my garage door opener. It just clicks. Its a craftsman opener. The lights are on but it does not move when the button is pressed.
If your door is stuck in the open position it is probably because the trolley is jammed against the bolt just in front of the motor. If so, loosen the chain enough to release the pressure on the trolley and run the opener until the door is closed. With the door closed locate the 'up limit' control on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
My 20 yr. old Craftsman 1/2HP chain drive GDO (139.18590) will click and hum for a second but the door doesn't move when I press a remote or wall console. The door moves freely manually and I checked the...
If your door is stuck in the open position the trolley is most likely jammed against the bolt just in front of the motor unit. You should be able to loosen the chain enough that it releases the pressure on the trolley and then close the door. While the door is closed, locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover and then tighten the chain.
Feb 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Craftsman 1/2 horse garage door opener. When I push the button, I can hear it hum, but the chain won't move and it seems the sprocket is frozen?
If your door is stuck in the open position you will find the trolley is jammed against a bolt just in front of the motor unit. Remove that bolt and run the opener until the door closes. Now locate the 'up limit' control on the side of the motor unit and turn it 2 times in the opposite direction of the arrow printed on the cover. Replace the bolt.
Sep 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door went up, now won't go down
take out bolt from rail that trolley is stuck against. try it now. happens sometimes
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opener only makes clicking sound when activated by remote or wall
where is door trolley, up or down. did it go up too far and wedge against bolt in track. take out bolt to release and try. put bolt back in. did you overheat motor. wait 15 minutes. give more info. (Does light bulb blink 10 times, then safety beam problem affecting door going down).
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't open or close
is trolley jammed against stop bolt. take out to release tension on chain. may be bad circuit board. how old is unit.
Jan 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 13953637SRT Remote is Equivalent to the 81LM Logo
61 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
