Question about Plumbing
Delta+single handle bathroom sink faucet dome is stuck
Dome removal procedure Dome is stuck Channel Lock Pliers failed
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 659 Answers
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Posted on Apr 06, 2009
SOURCE: Water suddenly stopped flowing from faucet.
This happened to me just tonight, "slam" and all on a Delta 470. The gasket that leads to the pull-out hose corroded and finally slipped free, lodging itself in the hose. Just pull off the hose by removing the plastic clip, then pulling on the hose with a good tug, it should come free. The destroyed gasket was sitting right in the connector in a perfect spot to block the water any time it was turned on. This particular gasket is a "second layer of defense" gasket, but even though the faucet probably won't drip without it, you should probably still replace it.
Posted on Apr 15, 2009
  • 4 Answers
SOURCE: Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Posted on Jun 13, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How do you remove the spout cap (RP34090) from a 2 handle delta 2402 kitchen faucet? The spout cap is stuck.
If you are talking about the aerator at the end of the spout,take a pair of pliers and a rag put the rag on the aerator and turn counter clockwise(take care to make sure rag is covering all the area and that should help you get it off.If you plan on replaceing aerator which is about $6 just take the pliers and take it off.
Jun 10, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
Have hot water in the bathroom sink spigot, but the shower is the single handle and turned on all the way, water is not hot...too much cold mixing, How do you adjust it?
You need to take the handle off...ususally held on with a small allen screw on the bottom side of the handle. After removing the handle there should be a dial setting.
Feb 18, 2011 | Delta & Single Handle Shower Faucet
How to disassemble the delta single handle bathroom faucet
Before taking it apart, you need to turn off the cold and hot water valves under the sink. Once you have done that, open the faucet and let the remaining water run out into the sink. Since I am not sure what the age of your faucet is. I will be using instructions for a common Delta faucet.
1. There is a hole towards the bottom of the handle in the front. It may have a plastic button there. If so, pry the button off with a very small flat head screwdriver. Try not to damage it.
2. If your going to replace the seals, it is best to by the rebuild kit that comes with a special tool. It includes the allen wrench and spanner wrench in one. And all necessary parts to rebuild it.
3. Once you get the handle off, you will see a dome shaped part with two notches in it. It may have ridges on the side of it. That is the special fitting that holds all the parts down.
4. Remove the dome shaped part with the tool provided with the parts kit.
5. Replace all parts that match yours.
6. Install everything in reverse order and you should be good to go.
Don't forget to vote
Everyone have a great Thanksgiving
Nov 23, 2010 | Delta Home
I have a Delta Waterfall 172 SSWF faucet in my kitchen. I need to replace the water spout - I have the replacement spout. It appears there is a plastic retainer ring that holds the spout in place but I'm...
Normally you just turn that ring, counter clockwise. If too hard to turn, I usually put a rag over it, to avoid scratching, and use a pair of channel lock pliers, and squeeze just hard enough not to slip.
Jan 15, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
DELTA SINGLE HANDLE GOURMET SPRAY faucet
Hello. Actually it is not difficult to remove the faucet. If you can pull up the sink with faucet attached it will be very easy. Otherwise get under the sink with a flashlight and you will see what tools are needed. A special extendable faucet wrench from Home Depot would come in very handy. Regards. Joe
Jan 14, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Need to replace cartridge in single lever moen kitchen faucet .Walk me through the process.
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Dec 12, 2009 | Moen Plumbing
Delta single handle kitchen sink faucet
Tuen the stops off unsder the sink . Remove the alaen screw from the handle. Using a spanner wrinch or a needle nosed pliers spred apart unscrew the large nut that has two slots. Lift the whole assembly out. Take assembly to the plunmbign supply and match ius the kit that youy need with has two new rubber seals and two springs and maybe a new spanner nut. It also comes with the spanner wrench  and allen wrench  needed to renstall. Tip you may be able just to tighten the spanner nut(clockwise) and stop the leak w/o rebuilding it.
Mar 28, 2009 | Kohler Forte entertainment remote valve...
Plumbing Logo
52 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
