Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Leaking water from back of motor - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
    Scholar:
  • 117 Answers
The 350 engine has two freeze plugs on the back of the block between the engine and the trans. Also could be the intake manifold gasgets. It could be the heater port on the intake(front right of intake) that runs along the top of the intake and then off the back of the engine
Posted on Nov 02, 2013
Water leak and burning smell
have a pressure test done on the coolant system . The leak at the back of the motor will be from a rusted welsh plug and if it is close to the fire wall will require the motor to be pulled for repairs because of the lack of room
Jan 07, 2014 | 1990 Dodge Dakota
Water leak in back of motor
have a pressure test done on the coolant system and look for a rusted /leaking welsh plug around the motor block and head.. If it is the block and is next to the fire wall then be prepared to pull the motor to have it fixed.
Jan 07, 2014 | Dodge Dakota Cars & Trucks
Water leaking from the back( of the motor)-the fire wall
probably from a rusted welsh plug in the back of the block or from the head. If it is near the fire wall then be prepared to pull the motor as there is no room there to do the job.
Jan 04, 2014 | Chevrolet Cars & Trucks
Water leak from back side of motor
Freeze plugs in each head as well as in the block will leak over time. Don't just replace one...replace them all or you will keep having leaks as each freeze plug rusts through enough to leak.
Aug 13, 2017 | 1998 Oldsmobile Intrigue
Antifreeze leak side of motor
is it leaking on the side of the motor where all the pulley's are or is iton the back side of motor if it is where the pulley's are it sounds like the water pump is leaking or is bad if it is on the back side of the motor it sounds like one of the freeze plugs is leaking or busted
Mar 14, 2012 | 2003 Buick Century
We replaced the theromostat and the radiator but it is still leaking under the car on the drivers side
Leaking water on teh drivers side indicates a cracked block or cracked head in most cases. Unless you have a water injected motor, I don't remember Ford using one, there are no water ports on that side of the motor. It could be the water pump leaking and being pushed back when the vehicle is running so check for leaks around the water pump. You need to check the heads, side of the engine block and the freeze plugs to make sure there are no cracks or leaks around the head gasket seal.
Jul 06, 2011 | 2000 Lincoln LS
Water was leaking inside on passengers side, now
HVAC drain tube was blocked and condensation could not drain to the outside of the vehicle
as a result the water pooled inside the HVAC case leaking on the inside and killing your blower motor and probably blower motor resistor
clear the drain, replace the blower and resistor and you'll be back in business
Jun 08, 2010 | 2001 Oldsmobile Aurora
I have replaced a water pump in a 98 dodge dakota sport after i put the motor back together and put water in it it still had water pouring out of the bottom of the motor. is there a freeze plug or a bypass...
yes there are freeze plugs are you sure your hose clamps are tight,is this leak the reason you changed water pump, you need to have this truck on a hoist so you can find the origin of the leak
Dec 27, 2009 | 1998 Dodge Dakota
Radiator water leak,
check to make sure the thermostat housing isn't leaking. as this is a common problem on rebuilt motors. the only other place i can think of is to check the freeze plugs, not usually the case. also check water pump.
hope this helps.
please rate good.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 02, 2009 | Suzuki Vitara Cars & Trucks
Leaking antifreeze but not from hoses and there is no water in the oil could it be a freeze out plug
antifreeze is pouring out of my car but its not from the hoses its looks to be coming from the back of motor
Jul 23, 2008 | 1996 Chevrolet C1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
32 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
