Question about Metabo Saws
Height of bandsaw without stand - Metabo Saws
    Sergeant:
  • 468 Answers
What's the unit of your band saw? There's a metabo unit that has 925mm working height without stand.
Posted on Jan 21, 2013
Measurements of hisence 50 inch 4K tv
From Best Buy's site I found this 50" 4k HiSense TV
http://www.bestbuy.com/site/hisense-50-class-49-5-diag--led-2160p-smart-4k-ultra-hd-tv-with-high-dynamic-range-black/4982500.p?skuId=4982500
With the following dimensions listed:
  • Product Height With Stand 27.7 inches
  • Product Depth With Stand 9.7 inches
  • Product Height Without Stand 25.6 inches
  • Product Depth Without Stand 3.3 inches
  • Product Weight With Stand 28.2 pounds
  • Product Weight Without Stand 27.6 pounds
  • Width 44.1 inches
Apr 03, 2017 | Televison & Video
How can I cut wood 3.5 inches thick with Dewalt Scroll saw?
nope... throat on scroll saw is of fixed height... beside, all scrollsaw blades are of fixed length, i would suggest use of bandsaw with very narrow blade with minimal kerf. do not use pressure on the blade! you will then have same cut through the thickness of the wood! setup bandsaw correctly, do not overtension it - see my other instructables pertaining to the bandsaw and regulation/setup of it
if you find my solution helpful - do not me shy... give some points... :-)
Jan 23, 2014 | Dewalt DW788 20" Variable-Speed Scroll Saw
How to install belt on rikon 10-325 bandsaw
For the high speed, (2950 ft/min), the belt should be installed on the rear pulley of both the motor and the wheel. For the low speed( 1445 ft/min), the belt should be installed on the front pulley of both the motor and wheel. To properly adjust the belt tension, turn hand wheel until there is 1/2" deflection in the "multi-vee" belt. Check this link to see the manual. http://www.highlandwoodworking.com/library/manuals/10325_manual.pdf
By the way, where do you get your band saw blades? I got mine from sawblade.com and I happy with them.
Dec 13, 2013 | Rikon 10-325 Deluxe 14 inch Bandsaw with...
HOW CAN I FIND AN OPERATORS MANUAL FOR DELTA BANSAW 93L 99060, 28-245
Visit this http://bandsawmanuals.com/manuals/view/341 . You have to register first before you can download manuals for free. Hope that helps .
Jan 11, 2013 | Delta Height Attachment for 14" Bandsaw
How do you fold a bandsaw blade?
gently twist it in half and then fold back against itself. USE gloves when doing this. Once you make the ftwist it will sometimes naturally fold.
May 23, 2011 | Delta 28-052 14'' Band Saw Blade for use...
My bandsaw don't work right, I go to cut wood ,the blade turn all difference way, I where out the block on the guide , It just don't work right
A couple options. 1. New blade. A dull blade will swivel around like that. Especially with a tight grained wood. 2. All the guides need to be properly adjusted including the height, both lateral guides, and the back guide.
Dec 19, 2010 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
Delta bandsaw cat. # 28-203 need manual
need a manual for a delta band saw, serial #91F36294, cat.# 28-203. Can you help?
Jan 30, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Panasonic 58
Greetings PBuffy,
The specifications are as follows:
Product Height 38-1/4" with stand (36-1/5" without)
  • Product Width 57-3/10"
  • Product Weight165.4 lbs. with stand (141.1 lbs. without)
  • Product Depth 16-1/2" with stand (5-2/3" without)
  • I hope this helps!
    Thank you,
    Agent Dort,
    Go Ahead. Use Us.
    Apr 15, 2008 | Televison & Video
    Saws Logo
    Top Metabo Saws Experts
    Vernon Taylor
    Spud Howell
    JOHN LAPIER
    Are you a Metabo Saw Expert? Answer questions, earn points and help others
