Question about Acer Aspire 4720 Notebook
Sansui no signal - Acer Aspire 4720 Notebook
  • Acer Master
  • 27,725 Answers
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Posted on Jan 20, 2013
When i turn my tv on it is saying signal strenghth is low
that"s i have good ideal for it. making sansui lcd tv connect to vcr . try it maybe have strong signal. good luck!
Sep 03, 2012 | Sansui 19 in. LCD TV
Sansui HDLCD1908B Television
call you digital cable provider
Jul 23, 2012 | Sansui HDLCD1908 19 in. LCD TV
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
Sansui 42'' HDMI problem
howto get the hdmi signal thro hdmi to dvi cable in plasma pdp42 sansui tv in dvi input
May 03, 2009 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Digital Conversion for DFTV270A
A VERY short search on Google (first hit when using "DFTV270A digital") shows this:
Amazon.com: SANSUI DFTV270 27" Flat Digital TV with ATSC/QAM Tuner ...The DFTV270 receives digital terrestrial and cable signals without the need for an additional tuner.
People should at least make a minimal effort in looking up answers for themselves. An equivalent questions is asking if a FlexFuel can use E85 gas.
Jan 18, 2009 | Sansui Televison & Video
Sansui HDLCD1908 not recieveing Digital channels
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Jan 06, 2009 | Sansui 19 in. LCD TV
My sansui 19 in lcd tv is not receiving signal from my dell compu
check the cable,check the graphics adapter is seated in ur system perfectly,check if any boot sirens came from ur cpu when starting the system.
Jan 04, 2009 | Sansui 19 in. LCD TV
HOoking up DVD/VCR without correct connectors
either use an old vcr to act as a signal converter or go buy an "rf converter" from an electronics store to change composite audio/video signal to channels 3 or 4 and that should do the trick.
Dec 26, 2007 | Sansui COM311AD 13 in. Combo
Sansui VRDVD4005
unplug the system and plug it back in to re-set it
Feb 04, 2007 | Sansui VRDVD4005 DVD Player/VCR
Acer Aspire 4720 Notebook Logo
233 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
