Question about Microsoft Internet Explorer 9
How do I change the original default setting for no add ons mode?. Originally specified when installing iexplorer 9, windows 7
The manage add ons function in internet explorer allows no changes in status, although the original set up specified additional add ons could be made later.
  • Microsoft Master
  • 1,824 Answers
You can use Internet Explorer with no-addons by going to Start/All Programs/Accessories/System Tools/Internet Explorer (No add-ons).
There are no except Flash.
Posted on Jan 20, 2013
sorose4u
  • 217 Answers
SOURCE: Internet explorer 7 unable to save settings
Try this it helped me:
Go to Registry Editor:
Click START>RUN>type "REGEDIT"
d351959.gif Add following DWORD Values:
'HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main"
Add New DWORD Value called "RunOnceHasShown" and set the value to "1"
and
another DWORD Value called "RunOnceComplete" and set the value to "1"
Restart the Internet Explorer and it should be fine.
Posted on Feb 05, 2009
steinja66
  • 52 Answers
SOURCE: Web pages won't load, but internet connection is fine.
Check the Proxy settings in the LAN Connection area.
Here is a document which provides information on the Proxy Settings. You should have NOTHING in the proxy settings. I suspect that you have something that is wrong.
http://technet.microsoft.com/en-us/library/cc817417.aspx
Posted on Apr 04, 2009
RonPark
  • 855 Answers
SOURCE: When I open Explorer 8 a window opens which says
You don't have to just go to your control panel, then to programs and features(if you have VISTA) or your remove programs feature. When there click on explorer 8 and remove. Another option which is what i did when mine didn't work was I went to system restore under system tools. Then restored the system to an earlier date before I had 8 and now everything works fine. I have since reinstalled 8 and have no problems at this time. There are a few problems with 8 still to be worked out but it should work fine some day.
Posted on Sep 26, 2009
richard191
  • 691 Answers
SOURCE: I cannot display either Windows explorer 7 or 8
Hello
Thank you for using
FixYa for your problem
ok, is it only the Home page not working, if you manually type in a website you do get there page.
I am thinking the Home page link is a old link and now dead. manually type in the address for the home page and see if that works
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 19, 2009
SOURCE: I have Windows 7 and internet explorer 9 (64 bit) installed. However Internet explorer is not working. It freeze and notice that CPU usage rise up to 100 % when internet explorer is launed. Could you
try firefox ;)
http://www.mozilla.org/en-US/firefox/fx/
Posted on Jun 19, 2012
Gateway desktop critical error code
Which operating system ???
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
Tip
Some useful commands
JUST PRESS [Win] + [R]
Try this out
1. %temp% :- Temporary files folder. your recently downloaded files,unzipped setup packages,etc.will represent here.
2.appwiz.cpl :- Add/remove programs window for uninstalling applications.
3.hdwwiz.cpl :- Add Hardware wizard for connecting any new piece of equipment your recently connected to your computer.
4.fsquirt :- Bluetooth File transfer Wizard for sending and receiving files from your bluetooth enabled mobile phone/PMP
5.calc :- Calculator.
6.charmap :- Character Map for inserting special characters such as copyright and trademark symbol
7.chkdsk :- Check disc Utility.
8.devmgmt.msc :-Device Manager for troubleshooting hardware.
9.cleanmgr :- Disk Cleanup Utility for cleaning up your temporary files and retrieving wasted hard-disk space.
10.dfrg.msc :- Disk Defragment Utility
11.diskmgmt.msc :- Disk management to help you manage your hard-disk partitions and removable storage devices
12.diskpart :- Disk Partition Manager
13.desk.cpl :- Display properties for changing display resolution.
14.gpedit.msc :- Group Policy editor.
15.ciadv.msc :- Indexing Service settings.
16.intelcpl.cpl :- Internet Properties.Very helpful when you want to change your proxy settings without going through Internet explorer.
17.iexplore :- Internet Explorer
18.logoff :- Log off from your account.
19.main.cpl :- Opens Mouse Properties.
20.main.cpl
Keyboard :-Opens Keyboard Properties
21.ncpa.cpl :- Network Connections Window to manage your networks.
22.netsetup.cpl :- Network Setup Wizard to create an ad hoc network among other things.
23.notepad :- Notepad.
24.perfmon :- Performance Monitor
25.powercfg.cpl :- Power Management to change power profiles.
26.regedit :- Registry Editor.
27.services.msc :- Services to disable unused services and boost computer speed.recommend you not to play around with this,unless you are an advanced user.
28.fsmgmt.msc :- Shared folders
29.shutdown :- Shutdown Windows.
30.msconfig :- System Configuration Utility, mainly used to change boot options and disable startup items.
31.sysdm.cpl :- System Properties.
32.taskmgr :- Task manager for killing processes that are not responding and monitoring resource usage.
33.firewall.cpl :- Windows Firewall
on Dec 04, 2009 | Computers & Internet
How to remove certified toolbar
Uninstall via "Programs" in control panel. Then go into the browser settings choose "manage add-ons" and ensure there are no toolbars installed. Also change your search option to google as default for safest results.
Jan 25, 2013 | Microsoft Windows 7 Home Premium 64BIT...
My gatewaylt2802u i cant find its webcam
Open the Device Manager, Imaging Devices, is it there? Scan for hardware changes. Open Windows Updates, install all updates. Search Gateway website, select your OS 32 or 64bit: http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2373 Download driver for webcam. You may have to use the Vista driver. Change compatibility to win 7. What was the OS originally?
Dec 20, 2012 | Gateway NV5214u Notebook
DELL Inspiron Notebook 9300 Win XP. The desktop
  1. Check mouse settings in control panel, see if mouse button settings are reversed. also check the touchpad settings tab, for additional settings there.
  2. Boot to the safe mode (F8 at startup, select safe mode on the menu) see if issue occurs in safe mode after trying step 1. Safe mode eliminates drivers as an issue, so if issue is still occurring, then it is likely a hardware issue.
  3. Boot to the Resource CD and run 32 bit diagnostics custom, on the touchpad see if it fails.
  4. If issue doesn't occur in safe mode, then there may be some serious software issues in the windows installation and it may be easier and faster to backup all data and pic and reinstall windows (or use PC Restore on that system) than to troubleshoot the current install any further.
Jul 01, 2011 | Dell Computers & Internet
My Hitachi dmp860 player displays the error message "NO AUTHORITY" when trying to play wma files that I originally ripped from my own cds. Why is this and what can I do about it?
When you ripped them, you probably used Windows Media Player which will add copy protection by default if you don't set otherwise.
Either
- Re-rip as MP3
- Re-rip with copy protection off
It is easier to re-rip than to try to remove copy protection.
http://windows.microsoft.com/en-US/windows-vista/Rip-music-frequently-asked-questions
And changing settings for ripping:
http://windows.microsoft.com/en-US/windows-vista/Change-settings-for-ripping-music
Mar 21, 2011 | Hitachi DMP-7 MP3 Player
Dual operating system trouble.
right click my computer -> properties
go to advanced - > start up recovery.
there is default operating system and also time to display list of operating system. tick that and set the time to 10 or 20 seconds
Jan 21, 2010 | Microsoft Windows XP Professional
How do you fix internet explorer
Sir/ Madam-
Normally this happens when customer Ie files are corrupted or Temp files are causing the problem..
Go to Control Panel\Network and Internet\internet option
Please try below steps it should fix the issue--:
Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Delete Browsing History.
  3. In Delete Browsing History, click Delete All.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK
Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  2. Click Tools, and then click Internet Options.
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK
Reset Internet Explorer 7 settings loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 7 to its default configuration. This was its state when Windows Vista was originally installed. To do this, follow these steps:
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click ResetSir/ Madam-
Mar 25, 2009 | Microsoft Windows XP Home Edition
Windows XP internet explorer
i think your internet security blocking iexplorer.
remove your internet security antivirus,reset your iexplorer to default settings and then remove iexplorer in add remove components in control panel.then install again.
check also in mozila fire fox .
Apr 09, 2008 | Microsoft Windows XP Professional
Windows xp
same prob but it solved
follow the process
1.load servicepack2
2. all driver
and notice that first u have yo install antivirus then
motherboard
Nov 15, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
