I have lost power to my compool lx3800.
There is a com port cable problem light on inside the subpanel. Suggestions to fix would be greatly appreciated.
  • 27,725 Answers
Not sure what compool lx3800 is if its not getting power make sure power lead is securely seated (if Applicable) also make sure drivers are up to date
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Posted on Jan 20, 2013
Anyone have a Baby Lock EMP6 simply freeze while sewing and display a "lost communication" message?
Sounds Like It Needs An Upgrade (more Info Needed Please!!)did you try to upgrade via laptop or computer (may be a bug in the software try to go into settings do a reset !! (more info needed Please!! ) Pleasure To Help You Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | Power Computers & Internet
My Compool 3000cp appears to be blank, I cannot select any features.
I would recommend a professional in this case. Those systems are very old. It may be a case of old wiring in the walls. Difficult to say.
Mar 31, 2014 | Pool & Spa
Compool 3000CP inside pool control is blank. I cannot select any features. It appears that there is no power going to it.
It could be one of 3 things, the indoor controller may needto be replaced, or the outdoor controller, or the wiring betwen the two, from your outdoor control to the inside house panel. your best bet is to switch out your old system with a compool to easytouch upgrade with the screenlogic interface bundle, or a Jandy Iaqualink upgrade. This will enable wireless access to the pool programs as well as give you control over variable speed pumps, which, if you dont have already, you will want to purchase.you will want a pool professional to install these items.
Compool cp3400
when the indoor control start the alarm , did you notice any error code display in indoor control like 170 ? POSSIBLE IS THIS control a pool only or pool and spa combination, did you have a pool heater connected to compool 3400 (PENTAIR)
Jun 14, 2013 | Pool & Spa
Major cirsuit breaker blew and partial loss of power in residential home ...is bus port still good? Looks good. replaced breaker and working again..will this last?
1) If busbar looks good it probably is good.
Usually when bus is bad, it has burned appearance, and looks like it is ready to crumble or is crumbling.
2) Problem with bad busbar, we sometimes add subpanel next to main box.
Buy subpanel box Home center or electric supply.
Square-D subpanel shown on following page came from electric supply.
http://waterheatertimer.org/How-to-install-a-subpanel.html
3) You can also add tandem breaker to main box.
Tandem breaker fits over one bus finger, but is actually two separate breakers.
Then double-up two lightly used circuits so you have room to move breakers around.
See image showing tandem.
http://waterheatertimer.org/images/ap-235-breakers.jpg
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 16, 2011 | Electric General Ted134050 50a 480v...
Subpanel feeder
Run 1 1/2" to 2" gray pvc conduit.
Mar 30, 2009 | Cooper Wiring Devices INC #BP4404V IVY...
Computer doesn't switch on!
The troubleshooting techniques you might try is swapping them out with another monitor and keyboard. If they work then you know its the monitor and keyboard if they don't work then the motherboard is bad. The ports for the keyboard and monitor are integrated into the motherboard. So you can't fix the ports, the whole motherboard has to be replaced.
Don't forget to rate this solution with 4 stars before you log out.
Jan 31, 2009 | Computers & Internet
Computer wont turn on
"Then I came across the recommendation to check the USB ports for damage. Saw some of the pins bent inside the port. Once I fixed them, the computer powered back on as normal! Small fix for big problem. Cheers - Parveen"
My wife's Dell E510 also suffered from the orange blinking light on front, and would not power up this morning. I had just purchased a new power supply for another computer and swapped it with the Dell's. To no avail... Put the Dell back together and still no luck with a start. So I came across your site and remembered that recently the 6y'o had jammed a USB port in the front of the Dell and after bending that USB port back into shape every thing works again!
Who would have thought that a free fix would be so easy!
Thanks!!!
Feb 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Firewire connection not responding
Take a magnifying glass to the firewire port on the camera. Check to see if it looks damaged at all. I've used firewire with my students for many years and this has happened to me on more than one occasion. The student is not as careful as he could be when plugging in the cable. The inside of the firewire cable becomes damaged. This is a cheap fix. Buy a new cable. However, when the port is damaged, it is an expensive fix. Since the computer recognizes another camcorder it may not be the computer. And if you are using the same cable, then it will probably be a hardware issue with the camera. Look at the port and let me know if anything looks out if place.
Jun 29, 2007 | Panasonic PV-GS65 Mini DV Digital...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
