Question about Craftsman 13953637SRT Remote is Equivalent to the 81LM
Garage door goes all the way down and continues to try and close more. It did not attempt to open.
    Master:
  • 969 Answers
Refer to your manual. The main control box has adjustment plastic potentiometers, usually on the back of the unit were the wires are. Using a small flat screwdriver you can adjust the up stop and down stop. There is 1 adjuster for each.
Posted on Jun 15, 2014
I need to know how to reingage a Craftsman garage door opener
All you need to do is cycle the door open and then closed.
Mar 15, 2017 | Building Materials
Craftsman 1/2 H/P garage door opener door goes closed but then opens
Try adjusting the "closed switch" forward a little in case the door is going too far when trying to close.
Sep 03, 2014 | Building Materials
HI, AFTER REPLACEING PLASTIC GEARS IN SAERS GARAGE DOOR O[ENER, OPENER WILL NOT GO THROUGH COMPLETE CYCLE. WHEN BUTTON PUSHED TO OPEN, OPENER GOES INTO CLOSE CYCLE AND HITS STOP BOLT. ATTEMPTED TO ADJUST...
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
Mar 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
When I try to close my garage door --4100 model-- the door travels part way down, then reverses and goes to the up position. I can force it closed by keeping the garage door wall switch continually...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have a bad sensor.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 Hp garage door opener doesn't stop going down despite (quite forcefully!) applying pressure in the opposite direction. It would buckle (and did) if I don't let it continue unhindered...do...
YOU NEED TO ADJUST THE DOWN FORCE.
YOU WANT TO TURN IT COUNTER CLOCKWISE TO THE STOP (THIS ADJUSTMENT IS ONLY ABOUT 3/4 TURN FROM MIN. TO MAX.). THEN TRY THE DOOR IF IT REVERSES TURN IT ABOUT 1/16TH TURN CLOCKWISE. CONTINUE THIS VERY MINOR INCRAMENT ADJUSTMENT UNTIL THE DOOR CLOSES WITHOUT REVERSING. THEN GO 1/16TH TURN FURTHER.
YOU SHOULD BE ABLE TO STOP THE DOOR AND REVERSE IT BY GRABBING THE BOTTOM OF THE DOOR AS IT GOES DOWN AND LIFTING SLIGHTLY. IF YOU CAN'T GET THE DOOR TO BOTH CLOSE AND REVERSE WITH MODERATE PRESSURE YOU MAY NEED ADJUSTMENT TO THE DOOR / SPRING / ETC.
- I DO NOT RECOMMEND ADJUSTING THE DOOR YOURSELF - CALL IN A PRO FOR THAT.
IF THE ADJUSTMENT IS SUCCESFUL ADJUST THE OPEN SENSITIVITY / FORCE IN THE SAME MANNER.
HOPE THIS HELPS
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not continue to open garage door.
You say your door won't open and then you say your door won't close. Anyway you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you tweak them and the lights don't come on then you have either a wiring problem or a bad logic board.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door reverses back to open position instead of closing
SOUNDS LIKE A SENSITIVITY ISSUE UNHOOK THE DOOR AND TRY IT MANUALLY TO BE SURE IT DOESN'T BIND OR IS TOO HARD TO OPEN OR CLOSE.
IF ALL IS WELL CHECK THE SENSITIVITY SETTINGS ON THE BACK OR SIDE OF THE OPENER.
YOU WANT THIS SET AS LOW AS POSSIBLE AND STILL OPERATE THE DOOR WITHOUT REVERSING.
NOTE: THE FULL RANGE OF ADJUSTMENT IS ONLY ABOUT 3/4 TURN SO MAKE A VERY SLIGHT ADJUSTMENT AND THEN TRY IT AGAIN.
HOPE THIS HELPS
Feb 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not work
My Garage door goes down half the first time I'm attempting to close it; then closes completely the second try. What's the problem?
Jul 18, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Craftsman 13953637SRT Remote is Equivalent to the 81LM Logo
346 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
