Question about Dell Computers & Internet
Virus cont get on the internet
  • Dell Master
  • 1,824 Answers
if the problem is not a virus:
try checking your cable for any broken places, or go to the place where you bought your PC and they might help you!
Posted on Jan 20, 2013
I cont format my pendrive
Four possibilities here:
1. You either have a virus/malware
2. The data/partition table is damaged or corrupted
3. The firmware is damaged
4. The Drive is dying or dead
Scan it with a virus scanner and Malwarebytes Anti-Malware. If that doesn't clear it up then try flashing the firmware.
Good Luck!
May 22, 2012 | Electronics - Others
What means of po cont on canon np 6650?
PO cont means Drum Potential Control,
If po cont set to 0, it means scanner system adjust the document darkness automatically but you may face many printing problems such like auomaically over dark, over light, heizzy, dull, etc etc.
if you want to trouble free printing, please set PO-Cont to 1
Aug 11, 2011 | Canon NP 6650II Copier
Kenwood kdc-248u. Installing into a 01 mitsubishi galant. Using a wiring harness adapter to plug into the factory harness. The wires on the radio pig tail have a label of P.CONT, ANT CONT, and MUTE. Not...
From the installation instructions: Ant Cont - Motor antenna control wire (Not used) P. Cont - Power control wire - To the power control terminal when using the optional power amplifier or to the antenna control terminal in the vehicle. Mute - Mute control wire - To the terminal that is grounded when either the telephone rings or during conversation (this would be to the telephone that is purchased separately.
May 21, 2011 | Car Audio & Video
I think my laptop got a virus and i am unable to open Mcfee security center
check in safe mode. how?
shut the computer off//
cont hit f-8 key immediately you restart the computer. keep tapping f 8 till you get advance boot option.
make sure you connect the internet directly to the computer means remove the wireless connection if there is and hook it wired.
select safe mode with networking and login
check the internet and if it doesnot work then do system restore to prev date when the computer was working fine.
always make sure that the date selection should be sufficient if you are not sure.
selecting the date doesnot alter anything on the computer.
follow the wizard of system restore and the computer will restart automatically to normal mode.
if your security suite is not opening then you will have to uninstall it from prog and feature and get it installed properly..
May 15, 2010 | Toshiba Satellite M305D Notebook
Got virus
check if internet is working in safe mode with networking.
steps:-
shut the comp off//
restsrt the comp and immediately tap f 8 cont....
will take you to adv boot option//
select safe mode with networking//
hit enter once and again enter//
login and the comp should be directly connected with the modem//
if internet is working then download malwarebytes s/w and do the quick scan//
once the scan is over also remove the virus from quantrine (4th option) on the top//
if you find difficult then call up hp smart friend support and they will do for you. phone number is 1866-211-5207. charges is $59.99.
security tool is a virus and can create lot of other problem and crash the computer. so if you want to be on safe side and if you are not sure what you are doing then go for techj support. will save your time and lot of money too.. which you are not aware of.
May 09, 2010 | Microsoft Windows XP Professional With...
Correct eec for 1989 ford f150 5.8l
Here is a listing of all possible computer modules for that truck. Perhaps this will help in some way in your search.
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AL2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-ALA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-ALB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AN2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-ANA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-ANB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-AP2B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-APA
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Calif, ID E8TF-APB
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), High Altitude
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AK1A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E8TF-AK2A
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E9TF-Z1B
Elec Cont Unit (ECU), 8-351W (5.8L), (AT), Fed, ID E9TF-Z2B
Dec 15, 2009 | Ford F-150 Cars & Trucks
I keep trying to quarantine then delete issues with webroot anti virus but my computer keeps freezing up and won't do anything, when I cont. alt delete, it says task manager has been diabled by...
Sounds like you have spyware or a trojan rather than a virus.You can try a restore point if there is one or you can try SPYBOT to see if it can delete it effectively.Webroot is probably causing the freezing from not being able to shut the program down first then eliminating it or its not made to really get rid of spyware/trojans/worms etc at all.There are very few Anti-Virus-Spyware removers that actually work as well as they are advertised.
Oct 12, 2009 | Computers & Internet
I cont remove the mcafee from my compaq laptop
Go to the McAfee website and download their McAfee removal tool. By running this you will completely remove all of your McAfee software. You will then be able to install your Kapresky anti-virus.
Sep 22, 2009 | HP Compaq Presario V6000T Notebook
If we have lote of virus in oure sistem ,
Better get a good antivirus or you will be in bad situation (No Trials they don't work)
Kaspersky good choice
Feb 27, 2009 | Macromedia Computers & Internet
Hey i was wondering what some of the wires stand for im my cd player (kenwood kdc 138) eg,ant.cont and p.cont
Ant.cont. is used to control a power antenna. Radio comes on..ant. goes up...radio off...ant down.
p.cont. is used to turn on car amp.
barneyluc
Oct 02, 2008 | Kenwood Audio Players & Recorders
Computers & Internet Logo
12 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
