Question about Frigidaire GLTF2940ES Front Load Washer
Fridgidaire frontloader washer stuck on pause
My machine started the wash cycle then stopped about a minute into it then PAUSE comes up and I cant get it restated.
  • Official Brand Answer
  • 4,342 Answers
Hello Angela Gilmer - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. If fault reoccurs, then it typically means that the unit has a faulty door latch. If you aren't certain that the door is properly shut, then the latch assembly may need replacing. Contact a professional to assist with the repairs.
Posted on Jan 23, 2013
IFIXALL
  • 868 Answers
SOURCE: machine stuck on pause/err
un plug the washer for 5 minutes and re try
Posted on Jun 03, 2008
  • 190 Answers
SOURCE: err 10 message on Fridgidaire front load washer
The E10 error indicates a long fill error meaning the machine thinks it took to long to fill with water.
            We recommend u to check that the drain tube is now stuck to far into the stand pipe and possible causing as siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow.
             u can hook the drain hose off, forcethe  water through it with a water hose, unclog the stinky mess and  hook it back up again and  work it.. tat woul do..
Plz rate this solution.. thank you..
Posted on Apr 08, 2009
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
Krazytech
  • 725 Answers
SOURCE: the washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
Posted on Sep 19, 2009
  • 1531 Answers
SOURCE: Frigidaire Washer stuck on pause
does the unit have standing water still in it.if so use a shop vac and attach it to the end of the drain hoseand removed all the water the check you drain pump for any kind of foriegn object that may be stopping the impellar wheel.the door lock may also be bad, the last but maybe the first thing is a bad control board
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
40C cycle stopped with 12 mins on display - now nothing works
Press "end of cycle" & wait for 2 minutes then try the door, do not force the door........................ If problem persists go to your model above & click on your model number & look for solutions....should find something.
Jan 12, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Frigidaire GLTF2940ES Front Load Washer Logo
63 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
