Question about Dryers
WHIRLPOOL DRYER 5-6 YRS OLD
GOOD MORNING,
I DESCRIBED MY PROBLEM LAST FRIDAY, A GAS FIRED DRYER
MODEL LGQ9030PQI , APPARENTLY THE UNIT RAN THROUGH THE
NIGHT WITHOUT HEATING UP. I CHECKED THE IGNITOR, ITS FINE.
THE TIMER MOVES THROUGH THE MINUTE INTERVALS BUT DOES
NOT MOVE WHEN SET TO ENERGY PREFERRED. I'M NOT SURE
IF IT IS DESIGNED TO MOVE THROUGH THIS SECTION OF TIMER.
EVEN WHEN I PROGRESS THE TIMER MANUALLY IT DOEN NOT IGNITE. YOU INDICATED OHM METER TESTS. PLEASE ADVISE
BY THE WAY, I NOTICED THE US NAVY BALL CAP, I SERVED ON
THE USS SHASTA AE-33 FROM 79-83 THANKS FOR THE HELP JP
  • plumgps Jan 26, 2009
    THE IGNITOR IS NOT OPERATIVE AT ANY TIME BUT IT IS
    NEW AND I TESTED IT FOR CONTINUITY.
    Novelist:
  • 161 Answers
Navy 2nd Class Diver 1969-73
The Ignitor is fine? So, it heats on some settings and not others?
The OHM Meter test for continuity.
Some parts give a reading of a certain amount of OHM's but, most the time all you need to know is if you get any reading on the meter at all. This shows there is no break inside the part. You can check the ignitor this way also the solenoids on the gas valve.
If the ignitor glows red then shuts off and does not ignite the gas, this could be the sensor or the solenoids. The sensor located close to the ignitor, will detect the glow from the ignitor and send power to the solenoids on the gas valve.
Posted on Jan 26, 2009
  • Ron Buice
    Ron Buice Jan 26, 2009
    Ok, I bet the thermal fuse on the back is bad. The dryer will run but won't let the gas come on.
  • Ron Buice
    Also, check out ronbuice.com
    I have a link to USS Atakapa
    Hope I helped
Gas dryer heating element won't come on.
There is a controller problem to turn on the gas manifold to produce heat. Since you have it only one week old, let's take the advantage of the warranty to have a new controller unit replaced.
Jan 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My whirlpool dryer wont get hot
Does it heat up at all? If so, your vent may be clogged. First check the air flow to the vent. If it vents straight out from the laundry area, be sure it's got good air flow. If it ventys up inside the wall, you need to have the vent cleaned out for saftey reasons. If it does vent up, you could have a house fire. Or your safety t-stat or thermal fuse may be out. Call us for parts! 9728590929. Hope this helps you!
Aug 26, 2009 | Dryers
Dryer not drying
MAYBE CHECK UR GAS VALVE
Aug 18, 2009 | Frigidaire FGQ1442ES Gas Dryer
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer does not get hot
Most likely your heating element has gone bad. This will happen from a number of different things ranging from just plain age to clogged vents causing it to overheat and go out. Also with a gas dryer your thermostat may be bad. The thermostat tells the dryer when to release the gas and ignite the flame to heat the drum. This would be my first suggestion on what the problem is. There is also a thermal fuse on your dryer that may be the problem but I really think it's the thermostat. It's hard to say without hooking a volt meter to it to find where the current is stopping but these would be the most common causes. It's always a good idea to have your vents cleaned out at least once a year and if you have a long distance between the dryer and the vent outside get the entire hose cleared out yearly. This will save you money in the long run on parts and save you from any fires. With gas dryers, I have seen it a few times in homes, the lint catches fire due to the open flame and does a lot of damage.
Do try out the thermostat first, it shouldn't cost you but around 20 dollars for it. If you open up the back panel of the control panel you will find the wire diagram and it will show you where the thermostat is located. Do make sure to unplug the dryer first though. Trust me, 110 volts of electricity is not a fun feeling for anyone, I know from experience. If you have any other questions let me know. I hope this helps you out enough to get this fixed, I know what a pain it is to have your dryer out. Good luck.
Jan 22, 2009 | Dryers
Whirlpool dryer won't heat
Ended up replacing the solenoids and the burner ignited, flame stayed on. Problem appears to be solved. Thanks for your help and posting.
Jan 03, 2009 | Whirlpool LGR7646E Dryer
Noisy drum
You may have a rear drum support issue. There are 2 rollers,(supports), 1 at 4 o'clock and 1 at 7 o'clock. If the bushing in the roller becomes elongated,(elliptical), it will give a thumping noise, as you describe.
Below is a link with exploded diagrams and parts help.
http://www.repairclinic.com/0100_14.asp
Please rate my answer on how helpful it was in resolving your issue.
Thank you,
Dave E. (Illeagle)
Jun 16, 2008 | Whirlpool Dryers
Dryers Logo
85 people viewed this question
Top Dryers Experts
