Question about Whirlpool Duet Sport HT WFW8400TE Washer
Washer leaks while filling - Whirlpool Duet Sport HT WFW8400TE Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Remove the lower kick plate and see if you can tell where the leak is coming from. Post back the results.
Posted on Jan 20, 2013
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer leaks when filling,fill by pail no leak
Pat it sounds like you pressure switch or hose to it is bad.your washer isnt leaking its overflowing the tub right?I dont understand the rest of your question so ill leave it alone..
Nov 15, 2009 | Washing Machines
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Leaks out when it is filling.
Make sure the drain hose is higher than the top of the washer tub.
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
Water leak
I WISH I COULD HELP YA. LET ME TAKE A SHOT AT THIS: IT SOUNDS LIKE A HOSE IS LEAKING ON YOUR WASHER. HOW OLD IS YOUR WASHER?
RODNEY
May 14, 2009 | Kenmore Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Clothes Washer leakes when filling,it's a top loader.
When you say it is leaking when it is filling, where is it leaking ? Inside or outside the machine ?
I'lll try to help once I know the answer to the above
Jan 01, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet Sport HT WFW8400TE Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
