Where can i download a free schematic of the power supply and parts list?
SOURCE: Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
SOURCE: Magnavox 42MF437B 42-Inch 1080p LCD
First place to look will be the power supply module, look for bad caps, check the output DC voltages, it will be an in-depth troubleshooting to narrow down the problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
SOURCE: Magnavox 37MF321D/37 flicking on & off
Sounds like you need to repair the power supply, don't fret, it can be really easy. Here is a pair of youtube videos I made after following some advice on this website from other posters: http://www.youtube.com/watch?v=qSS6ycUxS98
SOURCE: I NEED A POWER SUPPLY AND CORD FOR A MAGNAVOX 15'
Either you can get this universal type available inthe market in any electronic spares store or it is easy too make one by yourself if you are familiar with electroncis.
All you need is a mains transformer with secondary voltage at 12 volt and 4 amps capacity, use a bridge rectifier , good storage capacitor of about 4700mfd/25 volts and if possible use a 12 V regulator so that the power is smooth, regulated and protected..
http://www.youtube.com/watch?v=oTOkHKPJsnM
