Question about Whirlpool EB9SHKXVQ Top Freezer Side by Side Bottom Freezer Refrigerator French Door
Water on floor whirlpool eb9shkxvq02
Water on kitchen fllor under refrigerator. the icemaker has never been hooked up so i assume defrost system?
  • 1462 Answers
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Posted on Sep 07, 2008
oscarn
  • 109 Answers
SOURCE: Model ET14NKXEW00 Top freezer 1996 model Whirlpool refrigerator
Water from the melted evaporator frost is normally drained down to a pan mounted on the compressor . The heat from the compressor is normally enough to vaporize this water. Sometimes the evaporation may be reduced due to- high humidity (in the kitchen). Try keeping the exhaust fan on for a while. Also check if the drain line is blocked or shifted out of the drain pan.
Posted on Nov 20, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
  • 56 Answers
SOURCE: refrigerator leaks water on the inside underneath the freezer
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Posted on Jun 10, 2010
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge is leaking from the bottom or the back i dont know which yet. but i see water on the right back corner on the floor. any idea what this could be
Greetings,
I guess, I need to know if its the floor of the refrigerator, or kitchen floor? if floor of refrigerator. Its most likely a drain issue..The defrost system melts the ice and that water flows into a drain. these become clogged from food particles and stop up. The water then travels the path of least resistence and ends up down inside refrigerator. The solution is to open up drain and usually all is well..
Now, if its just on the floor. we have to check all the obvious. it still could be the drain and water could be running out from under crispers onto the floor. So, check that first...if not, check the connections at icemaker valve (if you have one) again, check water line if you have one....make sure the drain hose is in the drain pan...sometimes the drain pan sits above the compressor and heat evaporates the water...these pans get a hole in them I hope this helps..let me know if you need any clarifications....Bruce
Nov 25, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
My Whirlpool refrigerator is leaking. We recently moved it to tile the floor. Now it is leaking on the inside. There is water in the freezer too, a coating of ice on the floor of the freezer. I turned off...
Defrosting unit might solve it, it sounds like your drain pan under your evaporator and the defrost element is not allowing any water to drain down to the pan on the bottom. Assuming this is a top mount freezer, remove the back panel and clean out the pan below the aluminum evaporator(the aluminum evaporator is on the back wall, looks like a radiator kind of, holds freon, do not puncture this) What you have to clean out is all the ice build up, or let it melt overnight, and pour some water down the little hole it the center to make sure it is open(hot water)
Jan 10, 2010 | Refrigerators
Aug 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice build up in freezer compartment until water flows onto floor.
Hi, Is this a wwhirlpool brand fridge?
The drain is plugged in the freezer section. If I could get model #,I can get you ezact instructions.
If the floor panel in the freezer has screws holding it in, remove the fllor panel. Now you will need to remove the rear panel inside the freezer as well.
If this is a Whirlpool brand, there is an after market drain heat strip that you will need to add to the defrost heater.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Refrigerators
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a GE side by side refrigerator and I just replaced the defrost heater last week because it would cool and than freeze up and I would have to turn in off and defrost it myself. Now it cools and stays...
Icemaker solid:
This could be a problem with the icemaker not dumping the ice or with the water valve in back not shuting off completely.
Water in the floor:
This may be related to the icemaker but first check the drain under the evaporator coils.
Dec 15, 2008 | Maytag MSD2656G Side by Side Refrigerator
Oct 24, 2008 | Whirlpool ET0WSRXML Top Freezer...
Whirlpool EB9SHKXVQ Top Freezer Side by Side Bottom Freezer Refrigerator French Door Logo
188 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
