Question about Konica Minolta MAGICOLOR 2300W LASER Printer
Replaced Black TOner but still says it is empty
I replaced the black toner with a new one. The light is still on and when I go print it says it is empty. On the status window it will not let me click on replace toner tab.
I have reset many times still same issue, very frustrating please HELP
  • Anonymous Mar 10, 2009
    But with cyan toner
    Problem Solver:
  • 6 Answers
One way you could reset the toner is using the service mode.
Is this printer a 2300w ? If so, open the front door of the printer, turn on and hold down the cancel button for at least 20 seconds, that resets all the counters to factory defaults. The only problem is, that it will set all the toners to 100% and standard capacity, but you can change that in the software. One good thing is, it sets the OPC drum,
Fuser unit, transfer belt, everything to 100%
Delboy
Posted on May 16, 2009
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
How do I reset the alert light still on to off ? after refill black toner ?
Replace the chip, or mite have a RFID chip then you need a new cartridge
Nov 18, 2015 | Ricoh Aficio Sp C222dn Color Laser Printer...
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
Printer is a Samsung CLX 3175FN. It says the
To run a quick check on your black toner, insert your old black toner back to the printer.
press on the menu button -> system -> report-> supplier info-> print. and same for your new toner, if it show u both the old n new black toner are under the same serial number. the new toner might be faulty. Invalid toner detected.
get the new toner with the box packing back to the shop for replacement.
Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
HP 2600n printer showing empty black toner
maybe u have to reset the printers counter..
Jul 22, 2008 | HP Color LaserJet 2600n Printer
Color cartridge
The Brother machine will not print if the message "Toner Empty X" ( X =C for Cyan, M for Magenta, Y for Yellow and K for Black) is displayed on the LCD. The empty toner(s) must be replaced in order to continue printing. Incoming faxes will be stored in the memory until the toner(s) is replaced.
May 10, 2008 | Brother MFC-9420CN All-In-One Laser...
How to reset Black Toner Empty Message on 2430Dl
There are many problems like that and its not recommended to change toner from one printer to another.
but you should try: put the old toner (emty) in again, then turn off the printer, change toner and turn on printer again.
if thats not helping, then maybe you have a old FW so you can try to update the firmware.
Jan 13, 2008 | Konica Minolta magicolor 2430 DL Laser...
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Toner Empty Message won't go off
check that the toner is inserted correctly, reboot print.
Aug 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
Open Questions:
494 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
