Question about Smith 2hp Pool Pump Motor A O Electric Pool Motor Replacement for 48y Square Flange Usq1202
Replace usq1202 pump
Looking for instructions, have done a Hayward in the past
  • jaxt315
    jaxt315 Jan 21, 2013
    Thanks, seems simple enough!
  • 372 Answers
It looks like since you have a square flange motor you have either a Tri-Star, a Maxflo II pump or other model by Hayward.. Either way the process is very similar.
Replace the seal, o-rings and gaskets with new ones. Use a teflon based lubricant on all rubber parts, including the seal, but try not to get any on the ceramic (white ring).
  1. Shut power off at the breaker.
  2. Remove the bolts connecting the motor plate to the pump housing.
  3. Back motor assembly out of pump housing making sure that the diffuser and its gasket also come out.
  4. Disconnect the electrical supply.
  5. Remove the diffuser if still covering the impeller, (there may or may not be screws to remove).
  6. Remove impeller ring (if one).
  7. Holding the impeller firmly remove the impeller screw. This is in the center of the impeller and has a REVERSE THREAD, meaning turn screw clockwise to loosen.
  8. Remove the end cap on the opposite end of the motor and use a 9/16" open end wrench to hold the shaft from turning.
  9. Unscrew the impeller CCW.
  10. IMPORTANT -- Note how both parts of the seal are oriented to assure the new one is installed likewise, then pull off the seal and seal plate, and discard old seal parts. Also note which way is UP on the seal plate relative to the motor.
  11. Reassembly to the new motor is basically reversing the steps above.
NOTES:
The impeller ring (if one) is a ring with a lip around one side. This goes over the center of the installed impeller with the lip facing outward, away from the impeller.
Do not over tighten the bolts! You can damage the pump by doing this. Snug plus about a quarter turn is plenty. In the event you have leaking after startup, open the pump back up and check you housing gasket.
Posted on Jan 20, 2013
Overheating hayward super pump
Superpumps have been a workhorse in the industry for decades. Your results are highly unusual. The motors that run these pumps have bee manufactured by Century/Magnetek and A.O. Smith for the past 20+ years. These same motors power the vast majority of pumps built by a wide range of pool pump manufacturers. (They are not Hayward specific)
You may want to get a second opinion from another electrician, or call out a pool pro to check out the installation to see what could be causing these frequent failures. This is WAY abnormal.
Jul 03, 2013 | Pool & Spa
How do I take my hayward Power Flo Matrix pump apart to replace the shaft seal?
The instructions are in your owner's manual, which you can also find on Google. No specialty tools are required.
Aug 04, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
REPLACE BEARING IN A USQ1202 POOL MOTOR AND STILL NOT SOUNDING CORRECT. NOT SURE WHAT GOING ON. NEED HELP
bad bearing, damaged bearing during install or a bad end bell= makes a low to high roaring noise over and over
Jul 15, 2011 | Smith 2hp Pool Pump Motor A O Electric...
Looking for instruction manual
Here is a copy of the users manual for the Aqua Bug pool cleaners. Hope this helps.
http://www.backyardcitypools.com/images/Hayward/Aquabug-Manual.pdf
Jun 19, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
Where do I find instruction manual(s) for Hayward Super Pump 15 HP SINGLE Speed W C17502 175 Sq Ft Cartridge Filter? Thanks
Copy and paste this link. It will take you to Hayward's main page, from there you can get any books you need.
http://www.hayward-pool.com/prd/In-Ground-Pool-Manuals_10201_10551_14502_-1_13502_13502_I.htm
Nov 22, 2010 | Hayward Super Pump 15 HP SINGLE Speed W...
Instructions for putting Hayward Model EC-75 filter on pump for a inground pool
Here is a copy of the users manual for these pool filters. It should give you detailed instructions about installing the Hayward Perflex.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Aug 30, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I am looking for a WIRING SCHEMATIC for the Hayward 5060 booster pump MOTOR. A wire came off and I cant find where to replace it.
Please comment with the motor manufacturer and the model and serial number off the motor nameplate. It is likely an AOSmith motor and the info will be somewhere on the motor frame.
John
Aug 25, 2010 | Hayward Pool & Spa
Smith 2hp Pool Pump Motor A O  Electric Pool Motor Replacement for 48y Square Flange Usq1202 Logo
125 people viewed this question
Top Smith Pool & Spa Experts
Mike Squire
Jay Finke
Jay Finke
Paul Carew
Are you a Smith Pool and Spa Expert? Answer questions, earn points and help others
