Question about Honeywell Humidifiers
Honeywell dehumidifier not collecting water but running
Model hld-10
2 Suggested Answers
  • 4736 Answers
SOURCE: DEHUMIDIFIER IS RUNNING BUT NOT
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Posted on Jul 28, 2011
Humidifier blows cool air only not collecting water
a humidifier doesnt collect water only disperses it. a dehumidifier collects water
Jul 05, 2017 | Humidifiers
Dehumidifer runs, but does not collect water. Just started this recently. We use it in the basement. Not too old. It's a Whirlpool Accudry.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 07, 2011 | Whirlpool AD25BBR 25 Pint Per Day...
The water doesn't come down when it's turned on.
heatman101
Jul 31, 2011 | Humidifiers
The humidifier appears to be working (with sound ) but is not collecting any water-cleaned the filter and still the same -the lit up area where it usually has the numbers is sitting at P2- I have lost the...
Alison -
A humidifier will not collect any water. A humidifier has a tank that you fill with water. The water is released / forced into dry air to make it moist, usually by a fan or ultrasonic method.
A dehumidifier has an empty tank that gets filled by the appliance extracting moisture from the air. The tank will have to be manually emptied periodically, otherwise the safety / water level switch will shut the unit off so that the tank doesn't over flow.
I suspect that you meant to say dehumidifier.. and if so, please provide the manufacturer's name and model. The "P2" indication will be difficult to interpret without knowing the manufacturer's info.
Nov 22, 2010 | Humidifiers
Whirlpool accudry dehumidifier doesnt work, the fan runs, but i think theres something wrong with the compressor, it clicks (on and off it seems) every bout 5 seconds. what could the problem be?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Sep 14, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Dehumidifier not collecting water
do the lines from the compressor to the evaporator freeze up or ice up anywhere,if so it could be low on refrigerant,also check the start capacitor in the compressor power circuit,if its bad the compressor won't run
Apr 04, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Does not dehumidify
Hello. I am here to help. Let me begin by saying that a dehumidifier only needs to be operated if the humidity in your home is too high. If the humidity is low, the humidifier will have to work really hard to try and remove water from it.
Here is an overview of how the dehumidifier is supposed to work:
When the unit runs, the circulating fan and compressor also run. The fan continually draws room air over the evaporator coils, which are cold, and then over the condenser coils, which are warm. Because the evaporator coils are cold, the moisture in the room collects on them--just as the outside of a glass of icy liquid "sweats" on a warm, humid day. When the moisture on the coils increases, it drips off of the coils into the collection container.
The air then flows over the warm condenser coils and out into the room. This process removes water from the air and, because of the heat from the fan motor and compressor motor, the exiting air is somewhat warmer, as well as dryer.
May 20, 2009 | Whirlpool AD40U Humidifier
Humidifiers Logo
895 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
