Question about Saws
Change blade on performance 500w jigsaw - Saws
  • 14 Answers
SOURCE: change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Posted on Jan 18, 2009
  • 211 Answers
SOURCE: cant change a blade on 500watt pendulum jigsaw fmtc500js
Hi
There is a click mechanism to replace the blade at the top of the blade.
best regards savumihai71
Posted on Feb 12, 2009
  • 10865 Answers
SOURCE: B&D 7580 Type 5 jigsaw. Cannot install blade
take your saw to any hardware store and they will sell you a blade that fits your saw and show u how to change the blade. not all blades fit all jig saws.
Posted on Apr 21, 2009
  • 16 Answers
SOURCE: change a blade on a jigsaw
They all either have a screw at the side of the blade holder, or some have a hole in the top of the machine where a screwdriver is inserted and a screw loosened to release the blade, and retightened once the new blade is inserted.
Posted on Jul 07, 2009
  • 548 Answers
SOURCE: bought a jigsaw a bosch pst 54e how do i change
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it
Posted on Sep 24, 2009
Testimonial: "thanks.did the trick.use you again thanks"
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
How to lock the jigsaw blade to make straight cuts on my Boschest 1587svs?
Use a straight edge guide. Clamp it on the work so the jigsaw can run against it. Be patient and go very slowly.
Mar 04, 2017 | Blade Saws
How to change blade on a Chicago jigsaw
Harbor Freight Chicago Electric Jig Saw - Review - YouTube
? 2:21
www.youtube.com/watch?v=lSh0M4WIJTk
Dec 13, 2013 - Uploaded by AdamDIY
Chicago Electric - Orbital Jigsaw 92772 They change the design over time but some of the key flaws tend to ...
jigsaw from hell - chicago (electric?) brand - DoItYourself.com ...
www.doityourself.com/.../445560-jigsaw-hell-chicago-electric-brand.ht...
Mar 9, 2011 - Most blades either have a hole in the shank or the shank is shaped like a .... A brand new one is only about $25 and no tools for blade changes.
Oct 22, 2015 | Saws
How to fit blade in performer 350w jigsaw
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
Oct 18, 2014 | Saws
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
I have an old bosch 158IVS uh, what do you call a little reciprocating saw? jigsaw? anyways i can't for the life of me figure out how to change the blade. i've undone every screw. opened up the motor...
well the sawzaw will be drastically different from the jigsaw, but the jigsaw will have either a round twist lock that needs to be turned a little to remove the blade, or two screws that hold a flat plate that clamp the blade. and as for the sawzaw, it will be a twist lock, or a latch lock, the latch lock will look like a lever that needs lifted to remove the blade, and the twist lock is the same as the jigsaw.
Dec 30, 2010 | Saws
Change a blade on a jigsaw
Jul 05, 2009 | Makita Jigsaw Blade
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Milwaukee jigsaw with blade change problem
a new tool will cost you about 170. You could look for a used on on craigslist.
Apr 21, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Saws Logo
121 people viewed this question
Top Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
