Question about Applica Santa Fe Quesadilla Maker
Handle/latch broke off quesadilla maker. Now what?
Head won't lock
It sounds like the latch, link & lever assembly need to be replaced, it does require taking apart the mixer, but is a fairly easy fix.
Here is a link to the replacement part: http://www.mendingshed.com/24452-2.html
And also here is a link to the service manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
Page 15 will specifically talk about replaceing that assembly.
Jan 17, 2014 | KitchenAid KSM95 300 Watts Stand Mixer
Kitchenaid artisan ksm150 - Motor Head Locking Lever stuck in locked position
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the Motor Housing (1). The Latch Lever (3) is connected to the Latch (10)
and held in place to the Lower Gearcase (5) by the Latch Bearing Screw (8). This
screw is visible from the outside and located near the Latch Lever.
Tighten this screw to fix your problem.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Can't attach ice cream maker dasher
If the bolt is the hinge pin that the head swivels on when tilting it up, it can be pushed back in when the head latch is released and the mixer head is lifted slightly.
Jan 17, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Hello, i just put a cup of coffee into the microwave and now the door latch does not allow it to open, any suggestions?
your going to have cold coffee . when you closed the door it prpbably broke the latch ear.. you may have to remove the shell and relace it from inside and the replac handle . ****
Jan 09, 2010 | Food Mixers
The handle on my h600 that raises and lowers the bowl broke off. Where can I find a new one?
call hobart, give them the info off the name plate and they will mail you one.
Jul 19, 2009 | Hobart Food Mixers
Bowl won't stay up
Hi. Goto www.hobartservice.com and register for free.
Search for your mixer model in the Discontinued Products area.
Download file# F6731.pdf On page 4 find the drawing labled PL 2523 If your reassembly geometry doesn't match that of the drawing, you must correct it. If this solution has assisted you please rate it. Good luck!
ricardok45
Mar 22, 2009 | Hobart A200 Stand Mixer
Broken beater on the Bravetti ep586 HB
Look on unit and find maker and call and they will tell you where to find.
Mar 13, 2009 | Food Mixers
Mixing bowl is jammed into the base and won't come out
you may have the old style frame which is why the bowl jammed old bowls are no longer avaible you may need to purchace a new mixer
Dec 10, 2008 | KitchenAid K45SS Classic Stand Mixer
Applica Santa Fe Quesadilla Maker Logo
21 people viewed this question
Top Applica Food Mixers Experts
eyecam
Are you an Applica Food Mixer Expert? Answer questions, earn points and help others
