Question about Lexmark X464DE Mono Laser MFP, 38ppm A4 Mono, Print/Scan/Copy/ Fax, Duplex, USB/Ethernet Interface, ... All-In-One Printer
SET TIME ON A LEXMARK X464DE
We need to change the time on our Lexmark X464de
  • Theunis Visser Oct 18, 2013
    To set date and time: select MENUS> SECURITY> SET DATE & TIMENU
  • 19 Answers
SOURCE: lexmark x1270
did you replace with oem or generic cartridge?.if you used gen. you may have gotton bad cartridge(this happens alot),if oem,did you go into properties and use cleaning utility? if you did not,do it,then try again.it may also be the print head ,also in utilities,go through the steps in utilities to check all possibilites.
Posted on Sep 23, 2007
wayneard
  • 1901 Answers
SOURCE: Need Vista-compatible driver for Lexmark X1270 all-in-one
Go to this Fixya page for the instructions:
http://www.fixya.com/support/t1152254-laptop_not_communicating_printer_windows
Posted on Oct 20, 2008
yooperbud
  • 8637 Answers
SOURCE: lexmark X2470 printer wont print/connect time executable stopped
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
  • 10406 Answers
SOURCE: How do you stop the registration reminders for
After downloading the patch, did you actually "run" the '64RegReminder.exe' program?
Posted on Dec 28, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Cannot change/ save two default settings on X6570 Lexmark printer
    you can go to printers and faxes (XP) or printers (vista) in control panel Right click on the printer and click on properties. Go to advanced tab and click on printing defaults. It will pop up the printer printing preferences. choose the desired setting. To disable 2-sided printing, go to advanced tab in the preferences window and turn off the feature. Click ok to save all settings. Go back to general tab and click on printing preferences and set desired settings if there is a need. Click ok to save settings. Then, for all changes to take effect, click ok button on the lexmark 6500 series properties window. Try to print again. Hope this helps.
    Posted on Mar 09, 2010
    The network won't set up for the x464de
    usually you must install net program on cd machine in your computer after than change your set up on your network.always to set up network for copy hard but after that you install cd program you can do it
    Nov 27, 2013 | Lexmark X464de Multifunction Laser Printer...
    How to reset pc counter on lexmark x464
    Of course - why didn't I think of holding down 2 and 6 and turn it off and on - that's perfectly logical! Works great but the user interface certainly isn't very intuitive.
    Jul 23, 2012 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
    I am looking for a Service Manual for a Lexmark X464de all-in-one printer to facilitate the replacement of the fuser.
    Hi sandy shutt,
    You can check the manual here:
    http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_X464&page=product&frompage=null#1
    Hope it Helps ^ ^,
    Webby101
    Sep 16, 2011 | Office Equipment & Supplies
    I have a lexmark 464de mfp. How do i setup scan to e-mail on windows 7 on this network printer?
    Multi-function printers cannot scan and then e-mail the scanned image. They can scan and then fax a document.
    You need to scan the document, then save the scanned image, open your e-mail program and create the e-mail then attach the image file (file attachment) to the e-mail before you send the e-mail.
    Jul 08, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
    I have replaced my photoconductor in my Lexmark x464 and I still have a warning notification comming on. How do I reset it?
    Try:
    To restore factory defaults:
    1. POR the machine into Configuration Mode.
    2. Use the down navigation button to scroll to the RESTORE
    FACTORY DEFAULTS item on the menu.
    3. Press Select. The machine performs a POR.
    4. The RESTORE FACTORY DEFAULTS sets the MFP non critical
    parameters back to the factory settings.
    Note: Some settings are not affected: panel language, energy
    conserve, paper prompts, registration margins, and page count.
    May 20, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
    I can´t find the option to scan something. In the menu is no button to scan. Can you help me an tell me how I can scann?
    1. you may use adobe photoshop to scan images..
    2. on the menu, just click import then select the model of your scanner.
    it will automatically open the scanning software if not, the default windows imaging software
    Jun 13, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
    How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
    Make sure the paper type and size in both trays are the same. If you are using letter size for both trays, make sure the settings in tray 1 and 2 are the same. If the settings are the same and it still fails to grab from the full tray change the engine settings in diag mode. Hope this helps but if you need more assistance, leave a comment and I'll get back to it. Thanks.
    May 10, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
    Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
    1. On the home screen, touch Menu button
    2. Touch Paper Menu
    3. Touch Paper Size/Type.
    Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
    Feeder Type to appear as a menu item.
    4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
    5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
    Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
    6. Touch Submit.
    Submitting changes appears.
    7. Touch Home to return to the home screen.
    Hope this helps.
    Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
    Feb 17, 2010 | Lexmark X6570 InkJet Printer
    Lexmark X464DE Mono Laser MFP, 38ppm A4 Mono, Print/Scan/Copy/ Fax, Duplex, USB/Ethernet Interface, ... All-In-One Printer Logo
    236 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
