Question about General Electric WHDSR316G Top Load Washer
My Kenmore washer 24732 will not agitate unless i push down on it. how do I repair myself?
2 Suggested Answers
  • 10 Answers
SOURCE: Ge whdsr315 top load washer will spin but not
Sounds like the nut that holds the agitator on to the shaft is not tightend down or the agitator is not fully "locked" into place on the shaft.
Posted on Sep 13, 2009
Kenmore 80 series washer agitates minimally but when you push down on agitator slightly it agitates more and is now having trouble starting to spin tub is it a belt issue?
Check out: http://www.appliance411.com/faq/agitator-dogs.shtml You can buy parts here: http://kenmore80serieswasher.com/whirlpool-kenmore-washer-agitator-cam-kit-285809/
Jun 25, 2011 | Kenmore Washing Machines
Washer will not agitate
have you checked your motor coupling?
Aug 01, 2010 | Kenmore 24732 Top Load Washer
Agitator only works on bottom half. can I repair
if the clothes mover section on top quit,remove the detergent cup and with a 9/16" socket remove the bolt down inside,this will let you remove the clothes mover part,then you need to order the thrust bearing and dogs cam rebuild kit for this model
Mar 23, 2010 | Kenmore 22422 Top Load Washer
My 80 series kenmore washer will not agitate unless I push down on the center of the part that agitates. it pins fine. is this something I can fix myself? is it worth fixing or should I look at replacing...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
In answer to your other questions:
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Oct 24, 2009 | Kenmore Washing Machines
Agitator doesn't agitate - kenmore model 110
how old is the machine? agitator dogs in agitators have only been used for the past 15 or so years. sounds like you need to take the agitator out and replace the 4 dogs in the top of the agitator. not a costly repair.
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 24732 will fill and drain but will not agitate or spin
HI, Even tho it drains ok, does it spin? If it doesn't spin or agitate, it could be the coupler that attachec the transmission to the motor.The agitator is ok, it is designed to work that way. Please let me know if I can assist you further.
Thanks
Vic
May 17, 2009 | Kenmore 24732 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 70 model 24732
check the lid switch. that is the most common problem if not spinning.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore 24732 Top Load Washer
General Electric WHDSR316G Top Load Washer Logo
61 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
