Question about Ricoh Office Equipment & Supplies
How to resolve the service call SC571
After I changed the printer oil the message appeared on the printer as service call SC571. how can I resolve the service call SC571 in printer RICOH Aficio 3224C
4 Suggested Answers
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
  • 1479 Answers
SOURCE: ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Posted on Apr 02, 2011
Error code sc571
You need to fill the oil tank with "silicon oil" i'm I'm not sure where your're from, but where I am its virtually impossible to get it apart from a dealer or a company such as Katun.
Once you have replenished the oil the error code will have to be reset, I would only let an experienced tech do it as you have to enter the service mode on the machine, and pressing the wrong buttons can cause untold problems.
Sep 20, 2012 | Savin C2410 Cyan Toner Cartridge...
Ricoh aficio service code sc571
Apr 02, 2011 | Office Equipment & Supplies
Appel service technique Ricoh aficio 1232C super G3. code SC571. j'ai rempli le réservoir de l'huile de vaseline d'après les forums.mais toujours le...
code 571 low oil top up oil located back of copier reset code press yellow key 1 0 7 press red
key keep held for 4 secounds go in copy sp press 5 press lower cursor key untill you reach 5 810
sc reset code then turn copier off/ on
Nov 08, 2010 | Ricoh Aficio 1232C Color Copier
Two copiers. Gestetner DSM618d - Will not stop showing jam indicator in compartment B. Have a code to call service center error - SC571. No idea. Aficia 200 - keeps saying call service center. Ken...
for the jam code make sure after you have checked that you reset the side door correctly on upper and lower section and that the re is no paper caught behind the paper sensor arm as somtimes if pulled down it can tear and jam the sensor..the 200 might just need the pm counter change or reset..go into the service mode via clear[yellow] 107 then hold down the stop button till the creen changes copier sp and then 7. data log and you can reset the pm there...good luck A
Jun 15, 2009 | Ricoh Aficio 450 Copier
Ricoh 1232c Error SC571
SP 1-930-1 Forces the oil pump to supply silicone oil up from the oil
tank to the tank in the oil supply unit. If the oil end
sensor detects oil in the oil supply unit, this SP will not start the pump.
SP 1-970-1 is an oil removal process mode for the transfer belt.
SP 5-810-1 is a fusing reset but if the sensor isn't working properly, the code could pop up right away.
Nov 05, 2008 | Office Equipment & Supplies
How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
Oct 30, 2008 | Office Equipment & Supplies
Ricoh Aficio 1232c copier error code SC571
Enter SP 5-810 and set to 1, then switch off and on the machine.
Problem with copier Rex Rotary DSc232
571 A Fusing oil overflow
• The oil overflow sensor detects oil.
• When the machine covers are
closed, the oil supply unit is not
detected.
closed, the fusing unit is not
detected.
Possible causes :
• Defective oil end sensor
• Defective oil overflow sensor
• Defective sensor cable
• Oil supply unit not installed
Jul 08, 2008 | Office Equipment & Supplies
The 1224C Ricoh Photocopier keeps on displaying SC571 error message.
Try 'clear', '107', 'start' buttons. If that does not work, try different combinations, but '107 should be correct.
Jul 04, 2008 | Ricoh Aficio 450 Copier
215 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
