Question about Elements Of Design EVWC320 EcoFlush Close Coupled Toilet, White
My black water sewer system is clogged from the toilet down to the hose - how do I safely unclog it
How do I unclog the toilet in my motorhome
  • 979 Answers
You can try taking up the toilet to get access to underneath. Get a hose and try to pressure it out , by putting a towel into the opening with the hose and turn it on by holding the towel in place and be ready for back pressure which in turn will blast out the drain. This can be sloppy but effective.
Posted on Jan 30, 2013
Toilet bowl will not refill
It is possible that the vent pipe behind the toilet is clogged (or was not installed properly). Some bathrooms are set up with one shared vent pipe, and a clog in one of the lines leading to it can cause similar problems.
The vent pipe in each bathroom does 2 things:
1: it lets the sewer gas go past the bathroom and up out the roof so you don't get sewer gas in the house.
2: It breaks the siphon as water goes from fixtures down to the big sewer pipes in the house. If it isn't working for a sink, it's not much of a problem because air gets mixed in with the water as it does down the sink, and this breaks the siphon. But in a toilet, it jsut keeps pulling water down the pipe until the water level in the toilet gets low enough to let air into the pipe, breaking the siphon.
It's not an easy problem to fix and often involves removing walls to get at pipes.
A plumber can bring a snake tool and try clearing the pipes from below or from the roof, and might even be able to bring a steerable snake that lets him control how it goes through the pipe.
Apr 19, 2014 | Kohler Home
Toilet BLUBS downstairs when flushed upstairs.
Your sewer vent may be clogged, or if you are in the northern climates, frosted shut. When you flush the toilet the water displaces the air in the drain piping. The vent gives the air somewhere to go. If the vent is plugged the dispaced air forces it's way out through the path of least resistance( the lower toilet in this case).Pour some hot water down the vent where it comes through the roof to thaw it out.or run a snake down the vent. Hope this helps.
Jan 01, 2014 | Home
Sewer smell drain
are there any floor drains in the room and an unused bathtub or shower? if so the water may have evaporated from the trap and allow the sewer gas smell. try pouring water into all the drains and see if it is still happening. more elaborate problem may be a broken vent stack in a wall.
Apr 23, 2013 | Kohler Home
Hi My toilet back up so I plunged it ,water went down, then once filled clean water bubbled in toilet, then nasty toilet water started coming in my bathtub which sits next to it. I have now plunged &...
If water is backing up into the tub then you have clog downstream from that bathroom group. If water backs up when you ran water in the rest of the house then you have a clogged sewer service. With either case the house drain and / or sewer drain will need to be snaked. Most of the time it will be the sewer drain.
Jan 18, 2011 | Plumb Pak 1-3/8 Bath Waste/Overflow Assy...
My toliet is clogged and can't get the water to flush. i have plunged, empyt out the water, not sure what else to do...
sewer line is clogged get a pipe snake find the acess hole to ur sewer line outside and insert the pipe snake stick it all the way in and then go the other direction! this should clear it!
Nov 08, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Water takes longer to drain from shower.
A simple and safe way to unclog a shower drain is to use a wet/dry shop vac. Pop the grid strainer up with a screw driver, then shove the suction hose down the drain, then seal the hose with a wet rag. Turn on the wet vac, and you will feel slugs goe through the hose. Inside the wet vac you will find a hair ball.
Nov 04, 2010 | Saniflo Home
Hello all, There is a awful sewer smell coming from my bath tub, it leave some type of brownish film over the drain almost up to the spout, it fumes or what ever it is also burns my eyes some, I don't know...
Sounds like a septic back-up...if indeed you have a septic tank. This could happen very easily--just from flushing a tampon or cigarette ****. Also certain types of trees have a rapidly growing root system that does nothing but head for the nearest water source, growing and entwining into a septic tank, clogging it up.
If this is the case, call a plumber to get it unclogged, then get some root kill and enzymes to flush down the toilet every couple of months.
Aug 27, 2010 | American Standard 2748.328 Town Square 5'...
My Whirlpool Cabrio washer is backing up into and overflowing my toilet every once in a while during the spin cylce. But today, the washer was not running and the toilet overflowed. The toilet is located...
Your problem is not with the washing machine. I suspect that the drain line for your toilet is obstructed further down the line than your snake can reach. If you have a clean out riser to your sewer system, flush the toilet while someone else is watching the flow past the clean out. I would say that renting a sewer line snake at a tool rental like Home Depot would solve your problem. Good luck
Mar 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kohler will hot hold water in the bowl. As a result of this we get sewer smells in the house.
Turn off the water shut off valve to the toilet.  Get you a bucket and hold the hose in the bucket.  Turn on the water shut off valve to see if water will run through the hose.  If no water comes out, then your water supply line is clogged.  But if you get good water pressure flowing into the bucket, then you need to replace your cheap *** fill valve.  Go to Lowes and get a quality Korky brand toilet kit and install the thing.  See if that doesn't help you out.
Oct 21, 2009 | Home
New American Standard Flowise toilet won't flush
You have a sewer issue....it is entirely possible for other things to cause the toilet to loose water as they drain....but only if there is a sewer problem.....that is why there is an air gap between the toilet and the tank...(the trap) now I have been in this industry 35 years and the jet you speak of is in the bottom of the toilet that directs and forces flow down and out of the bowl as do the many small holes on the underside of the bowl lip ( I suspect ...as I have seen it MANY MANY time in the paste) that your old bowl may have had lots of calcium or lime build up (using lime a away occasionally helps) in the holes under the lip as well as other places...which reduces water flow and there by reduces pressure......but what you are describing is definitely sewer related....other water sources causing water to drain...bubbles...etc..I had a similar problem that occurred about once every 2 years in one of my homes...I had a tree root growing into my sewer line ...it would flush but on occasion...debris would get caught and a good plunging would help...but eventually...(twice) I had to rent a 3/4 inch snake from Time Rental...with a cutter head on it and remove the problem. Now your problem sounds exactly like an air gap problem...in that an overflow or something related is causing a vacuum assist when large amounts of water are drained...(ie...tub...washer...).as this happens the force the water carries and the lack of access to air in the flow causes vacuum "tugs" on other water sources attached to the sewer....take of your clean-out cover (usually in the back of the house and if you see water standing in it ....sewer problem....also you can have someone flush the toilet and eyeball the sewer/overflow...to see how it drains.
I hope this helps....good luck...thank you for rating my effort...the Fang.
Mar 27, 2009 | American Standard Colony 2388.012.222...
Elements Of Design EVWC320 EcoFlush Close Coupled Toilet, White Logo
47 people viewed this question
Top Elements Of Design Home Experts
Donni Steen
Tom Chichester
Are you an Elements Of Design Home Expert? Answer questions, earn points and help others
