Question about RCA EZ300 Camcorder
Camera not on
When switch on red light is on,but cam is not on,then have to take out battery then off,
The camera will not turn on even when connected to the power supply, and the red light stays on indicating is fully charged but when I try to open the dvd disk will shut off and will not work at all
your cam is inshut down protect mode there is
an electronics problem in your power converter inside the cam ;if the cam go on whit the battery its your power supply....
Feb 07, 2010 | Canon DC100 DVD Camcorder
Flash symbol flahing with flashing number E9101 but does not flash only infer red light
Try this........
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Hope it will solve your problem....
Oct 06, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
I cant recharge my battery
i just bought the cam can you tell me how long it takes to charge the battery . i have had it on charge overnight and i stiil have a red light the cam works when it is pluggedn in but as soon as i unplug it nothing works. the reading on the camera is saying that the battery is full
Jul 25, 2008 | Jazz DV-179 Digital Camera
Jazz DV179
just plug the other end of the charger into the mini usb plug on the cam.
a red light will flash on camera until fully charged. Then the red lighjt will stop flashing.
Jul 05, 2008 | Jazz DV-179 Digital Camera
Sharp view cam vl a10
my view cam is blury when you try to play any movies on it.
May 31, 2008 | Sharp Viewcam VL-A10U Camcorder
Not charging
It sounds like Amazon might have sold you a defective charger radio shack has a universal charger for your battery. Around 49.00 I got one and it works great I would first have you battery tested by a place like batteries plus to make sure yours is good.
Mar 08, 2008 | Casio Exilim EX-S600 Digital Camera
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
Battery wearing down when in camera
First do not leave the battery in your cam, it will affect the cam. Use prescribed battery. Charge the battery for at least 8hrs.
Jan 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Dropped camera
your batteries will proberbly dead. you should try changing them
Oct 08, 2007 | Kodak EasyShare C653 Digital Camera
RCA EZ300 Camcorder Logo
14 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
