Question about Kyocera FS-1035MFP
Error C3100 When I open the printer it says call service and the error c3100
    Problem Solver:
  • 7 Answers
This code means machine's scanner home possition error. Try to check scanner home possition sensor if fixed in its possition. if not try to check scanner lamp unit movement .
Posted on Jan 24, 2013
5 Suggested Answers
SOURCE: i also need a service
call service c3100
Posted on Nov 09, 2010
sodeep
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
SOURCE: i am geting an error code of c3100 call for
Your scanner cable broken or twisted inside. You need to call local representative for further action.
Posted on Jul 13, 2010
  • 165 Answers
SOURCE: I am geting an error code of c3100 call for
the power is turned on or at the start of
copying using the table.
Poor contact in the
Check the connection of connector YC4 on
the scanner PWB and the connector on the
scanner home position switch, and the continuity
across the connector terminals. Repair
or replace if necessary.
Defective scanner
PWB.
Replace the scanner PWB and check for
correct operation.
Defective scanner
home position
switch.
Replace the scanner home position switch.
Defective scanner
motor.
Replace the scanner motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Check if the mirror flames and exposure
lamp are on the rail. And check the scanner
wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
Posted on Nov 13, 2010
How to repair kyocera 1024mfp error code c3100
http://www.fixya.com/support/t6140540-also_need_service#solution-section
Feb 14, 2015 | Kyocera Office Equipment & Supplies
Canon Imagerunner C3100 shows error code E00012-0001
Drum motor error
Check the connector and replace the motor
Jan 17, 2013 | Canon imageRunner C3100 Copier
When i get my c3100 started i get an error code e 000013-0000 . can you tell me what the problem is
Waste toner bottle full, open front door, one screw, make sure small cut out in the neck of the bottle is clean afterwards.
Oct 31, 2010 | Canon imageRunner C3100 Copier
What is Canon C3100 error code E000008 0001
The reading of the fixing roller life counter has reached its upper limit.just reach the counter reading at svc mode.
Mar 06, 2010 | Canon imageRunner C3100N Copier
Error codes of my kyocera KM 1635
c3100 is a scanner home position error, does the scanner move when turned on with lid up? if not its the motor, if it moves then it mat be a sensor (usually "U" shaped in rear left under glass, or it could be "locked" for shipping, look for a switch on left side or under scanner unit. hope this helps.
Jan 11, 2010 | Office Equipment & Supplies
KM-2050 / error c3100
glass. Poor contact of
Defective scanner
home position
switch.
Defective engine
PCB.
Defective scanner
motor.
Sep 30, 2009 | Kyocera Mita KM-2050 Printer
E070-003
when i open the printer the unit will int.rot. and then the error will appear. tnx...From Canon Support Product : imageRUNNER C3100 / C3170 Title : E00351-0000 Problem
May 05, 2009 | Canon iRC3100 Printer
Kyocera FS-1035MFP Logo
4,284 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
