Question about GE JKP85 Electric Double Oven
GE Microwave Model JKP85 Plate does not rotate
The plate in the microwave does not rotate. Everything else works fine.
  • 27 Answers
Usually this is a bad turntable drive motor in the floor of the microwave but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
TheRepairGuru ----- www.repairclinic.com
Click here For: GE-Microwave-Parts
Posted on Jan 26, 2009
What size microwave oven do I need to replace a GE jkp85?
You may have to do all the work to find one! After you take complete measurements (length, width and height) you will need to go to the appliance store with many choices to match it up!
Jan 12, 2013 | GE JKP85 Electric Double Oven
No heat and no rotate of the turn table. Everything else seems to be working as designed. This is the microwave
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
Jan 16, 2011 | GE JKP85 Electric Double Oven
RE: GE cooking center microwave JKP85 - there is
I have exactly the same problem. I take it no one has offered a solution to this. Don't know if this is a lining coming loose and potentially dangerous. Anyone know?
Jul 05, 2010 | GE JKP85 Electric Double Oven
GE jkp85 Microwave oven appears to be working
Most likely related to magnetron and diode this is for qualified tech to do only.
Nov 13, 2009 | GE JKP86 Electric Double Oven
GE JKP85...Microwave works...Oven controls are dead.
try to replaced the keypad and spray a wd40 at the terminal of the keypad to mainboard.
Jul 17, 2009 | GE JKP85 Electric Double Oven
GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Oct 25, 2008 | GE JKP85 Electric Double Oven
Need exact model No for JKP85 Double Oven
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
Nov 25, 2007 | GE JKP85 Electric Double Oven
Turntable not turning and microwave not working
the switches are on the left or right side or both (there may be two).locate them and theres 2 wires on the switch.jump them out.if there bad replace them as it would be a hazard issue for radiation not to.
Aug 28, 2007 | GE JKP85 Electric Double Oven
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
GE JKP85 Electric Double Oven Logo
399 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
