Question about wikipedia.org
Vuze didnt shut down tidily
I got a message from vuze.telling me, vuze didnt shut down tidily.and to seek help to put it right?
How should I configure Vuze on my new laptop? SMC8014W-G TWC Modem/Router. HP Envy Laptop w/Windows 8
JRod3,
Your new Laptop is capable of Wireless N theoretical transfer rate of 300 mbps with two antennas. Your router is wireless G at max. theoretical transfer rate of 54 mbps. I would recommend replacing your router with one that has wireless N. I use a Motorola Surfboard SBG6580. With some routers you can go into your settings and disable the firewall which will help with the speed. Firewalls can sometimes be redundant if you have a firewall in your operating system (windows) anyway. Before you run out and get a new router I would hardwire your laptop to the router (cat5E cable) you have now just to make sure you don't have a bottleneck somewhere else. Then do a speed test using your Vuze program. You may need to Port Forward your router, not always necessary..... you can get lots of info at portforward.com on your specific router. Depending on your speed that you are paying for from Time Warner you want to make sure you have the right router as well. Here is a list Buy Your Modem Time Warner Cable . If you reach your desired speeds hardwired to your laptop then I would get the new Wireless N router. Good Luck.
Mar 08, 2014 | SMC Computers & Internet
Why does my vuze program keep shutting down saying something made it stop working?
try this and see if it helps:
Close the program
Right click it's icon
Select Compatiblity tab
Mar 27, 2013 | Microsoft Windows 7 Home Premium 64BIT...
No Display upon turn on of Asus Eee pc 1015pd....
The problem is in your motherboard, if everything else has been checked, sub out the ram memory for another stick just to be sure, if no change the motherboard has major issues.
Jun 12, 2012 | ASUS Eee PC
I was working in sage instant accounts version 8.2 when my computer crashed. Im trying to go back into sage but it comes up with the message 'you may only run one copy of this programme at any...
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
May 19, 2011 | Sage Instant Accounts 8.0 (013604ug)
Got a display message "Reduced Engine Power" the
When you receive this message it means that the computer has put the engine and components into protection mode. This computer has done this to prevent any further damage to the engine or transmission. You have to have the computer of the vehicle scanned to find the problem then you need to get it fixed right away. It could be a number of different causes overheating,Low Oil Pressure,Transmission pump problem, low coolant level, low oil level. Their is really no way of telling from this end without seeing the vehicle.Start by checking all fluid levels, Oil,Coolant,Transmission.If all this is good scan the computer with a OBII scanner or take it to a garage and get it scanned. It may just be something simple or it could be something very serious.Do not drive the vehicle it is worth the cost of a tow truck to prevent further damge if you can not determind the cause and fix it yourself.
May 09, 2011 | 2004 Chevrolet Tahoe
Cant message on facebook
ther is no any problem of kind u r telling.
u can keep on going writting messages.
Apr 07, 2010 | Computers & Internet
Nat problem
first off make sure that you manually allow the port exception on windows. second make sure the exception is added to your router, for example if your computer ip adress is 192.168.1.101 (run ipconfig in command prompt to find out) make sure the port is forwarded (use a number above 40000 and make sure it is not blacklisted). next if your router has uNap settings/NAT translation make sure you add vuze to its programs to monitor list.
May 06, 2009 | Computers & Internet
Downloaded genesis roma worked untill try to burn
Hi, I would say you need to reextract the rar file using whatever program you use. This should reassociate the rar file and allow the file to open again.
Apr 18, 2009 | Acer Computers & Internet
Torrent downloaders and Port Forwarding.
Hi !
Can you please try Vuze (http://www.vuze.com/Download.html). Vuze can bypass most of the ISP restrictions.
Thanks.
Mar 03, 2009 | Computers & Internet
Error message with sage instant accounts
Jan 13, 2009 | Sage Instant Accounts 8.0 (013604ug)
wikipedia.org Logo
24 people viewed this question
Top wikipedia.org Computers & Internet Experts
dhnguyen
Vernon Taylor
Peter J?rgensen
Level 1 Expert
Are you a wikipedia.org Computer and Internet Expert? Answer questions, earn points and help others
