SOURCE: Sony DCR PC110e camcorder
My problem with the DCR PC110E Sony camcorder is being unable to download my videos from tape to the PC or laptop through the firewire connector. Have you ever had this problem?
SOURCE: connect Sony Handycam DCR-PC5 Mini DV Digital Camcorder to my Laptop
try to install the cd software of your sony handycam into your laptop..
hope it will help thanks...
SOURCE: Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
SOURCE: Sony DCR-HC38 error C:31:22 re-insert tape.
Sony is a ******* piece of **** corporation that has foisted their name on professionals and consumers as being the epitome of high technology for all forms of media. They are, in fact, scam artists that have perfected the art of programmed obsolescence and early life failures for their equipment. Because I have been a professional video/audio engineer for 30 years, I have been forced to own and use more Sony gear than I am comfortable admitting to. There is NO answer to your dilemma because it is a defect programmed into the circuitry of Sony DV-Cams that will ultimately force you to take the machine in for repairs...again and again and again and again....
Do your self a huge favor and smash that piece of **** with a sledge hammer right now. Then, go out and buy a Canon. Great products and great tech support. Sorry I couldn't solve your problem for you. But, I am an engineer and I can't even solve this one myself.
