Question about Dell Computers & Internet
I dont no where to plug in the wirers on my tower
  • Dell Master
  • 27,725 Answers
Your Dell desktop computer will come with all of the equipment you need to hook it up and get it started right in the box with the main CPU. You will have all of the peripheral equipment and cables that you need to connect your desktop to your keyboard, mouse, monitor and, most importantly, a wall outlet or surge protector to provide it with power. The entire hook-up process shouldn't take more than a few minutes. Connect your computer monitor to your Dell computer using the included blue VGA cable. This VGA cable plugs into the blue video input on the back of your Dell computer and into the identical input on the back of your monitor. Plug your monitor's attached power cable into a wall outlet or surge protector. Plug in your keyboard and mouse. Dell computers ship with USB keyboards and mice, so take the USB cables that are permanently connected to each device and plug each of them into one of the available USB ports on the back of your Dell computer. You can use the ports on the front of your computer if you like, but as your keyboard and mouse don't get unplugged with any kind of frequency you may want to conserve those inputs for removable devices like flash drives. Connect your Dell computer to a wall outlet or surge protector using the included power cable. The power cable plugs into the power outlet on the back of your Dell computer and into a regular power outlet on a compatible device. Press "Power" on your Dell computer as well as on your monitor. Your computer will turn on and begin to boot into Windows.
Hope this helps. For reference, you may want to read this section describing the cables and connectors coming from the power supply, and/or this section describing the connections on the motherboard. Motherboards and system cases vary. Your motherboard may not have all the items I mention here, and the same holds true for your case. Furthermore, you may find that your case and motherboard don't match in every situation; for example, some cases have a turbo button and some do not, and some motherboards have a connection for a turbo button and some don't. Watch out for "off by one" errors when attaching cables to pin headers. In particular, some motherboards combine several pin connectors into a larger block. The individual connections are the same, the motherboard just physically groups the pins together into a larger matrix. Be careful when working with these as making a mistake is much easier to do. Refer to the manual. If the system is in a tower case, it is much easier to perform this procedure with the case resting on its side. LEDs have two wires and are unidirectional, so they will not work if attached backwards. You need to connect the positive lead from the case to the positive pin on the motherboard, and the same with the negative. Unfortunately, the case connector almost never has the positive and negative labeled. Fortunately, attaching them backwards will usually not cause any damage; the LED just won't work. One tip you can use: most cases employ for each LED one colored wire (green, yellow, red, orange, blue) and another wire that is either black or white. When this is the case, usually the colored wire is positive (signal) and the black or white wire is negative (ground). This isn't always true, but it's better than a random guess in most cases.
Posted on Jan 20, 2013
I dont know how to connect the wirers to my alternatorford 302 from 1989
big wire goes on the battery side (round with nut)of alt little wire should plug in on field side(should have a plug connector type
Aug 05, 2011 | Ford Econoline Wagon Cars & Trucks
Ok, so I have a 95 nissan maxima se and it has the stock radio with the tape player so I took all that out , now im about to install the new deck in but I noticed the wirers dont hook up with the stock...
Your best bet is to go to a good stereo store that can get you a wiring harness adapter that will plug into your car and be color coded to wire up to your aftermarket radio.
It will save you a lot of time and trouble.
Feb 04, 2011 | Pioneer DEH-1300 CD Player
P0306 CODE after tune-up? Cleared codes after.
If you bought the spark plugs at auto zone,these are factory seconds,and will fail under the ignition system you have,check the coil boots also,make sure they are good and the boots are on good,but it is most likely in the ignition area.
May 04, 2010 | 2003 Mazda Mazda6
Removed spark plug wirers need firing order Ford Expedition 1999
Several engine sizes there...
1999 Ford Expedition 4.6 liter SOHC V-8 VIN "6"
1999 Ford Expedition 4.6 liter SOHC V-8 VIN "W"
1999 Ford Expedition 5.4 liter SOHC V-8 VIN "L"
Hope this help to solve it (remmeber comment and rated this).
Apr 20, 2010 | 1999 Ford Expedition
I dont know where the Dell 725 Printer Power Cord goes into the tower Which outlet on the tower
The Dell 725 printer power cord does NOT plug in to the tower. The Video Cable, on the other hand, plugs in to the tower's video output. Look for a connector like the one from the printer (often USB these days) to plug it in to the computer. There was a diagram that came with the computer that showed how to do all the connections, and the Power Cord does NOT plug in to the tower. USB connections are in various locations on your computer's tower, in the back and sometimes in the front too.
Nov 09, 2009 | Dell 725 InkJet Printer
How to wirer to spark plug
http://autorepair.about.com/library/firing_orders/bl-fo-14344.htm
Try this web site for the info.
I hope this works!
Good Luck .!
Aug 09, 2009 | 1983 Mazda RX-7
Need wirering diagram to understand where to install
Get an adapter for your trailblazer from a parts store. There normally there are several ends to fit your new stereo
Apr 20, 2009 | 2006 Chevrolet Trailblazer
Help
check or replace plug wirers. could be the coil pack .located @ other end of plug wirer
Dec 06, 2008 | 1996 Lincoln Town Car
I took my van in for a basic turnup and oil change that was $264.
If you remove the engine cover from inside the vehicle you will gain access to the spark plug wires and spark plugs. The spark plug wires come out of the distrubtor cap thats at the rear of the motor, the spark plug wires run to the left side of the motor and to the right side an end up attached to the spark plugs. Reolace spark plug wires one at a time so you dont mix them up, this is fairly easy the only difficult part is getting your hands in the small space in the engine compartment. Hope this was helpful.
Nov 26, 2008 | 2001 Chevrolet Astro
Where do i plug it into my tower?
Does it have a large wide plug with lots of little prongs or a small one? If it is a large one, there will only be one place that it will fit on your tower and it will screw down. If it is a small one you can plug it into a USB port that has a little symbol on it to match your symbol either on the front or back of the tower.
good Luck
Thank You rating this solution!
Aug 18, 2008 | Brother MultiFunction Center MFC-440CN...
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
