Question about Sony Gv-hd700 Hdv 1080i Deck Hd Minidv Gv-hd-700
Gv-hd700 not recognized on computer
I'm trying to capture footage to my computer and it does not show up after hooking up the firewire cable.
SOURCE: Capturing Footage with Camera
USB streaming does not work for Windows Vista. Use the firewire/ilink connection instead.
Roger
Posted on Mar 17, 2008
charcois
  • 763 Answers
SOURCE: Sony DCR-TRV530 firewire connection not recogized on Mac; won't import or capture video
try to use USB wire and then install the driver to your pc. hope that helps you!
CHARCOIS
Posted on Aug 21, 2008
SOURCE: XP Pro w /firewire not recognizing Sony DCR-TRV730
Try a video card that supports current DirectX. Apparently it has an effect even if you capture without previewing the video. (worked for me, anyway).
Posted on Sep 26, 2008
SOURCE: dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Posted on Dec 01, 2008
  • 497 Answers
SOURCE: Sony DCR-HC52E connected with Firewire not detected in moviemaker
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 15, 2009
I have the sony DCR-HC26E handy cam i'm trying to connect it with my pc (windows 7) by using usb cable it wont work my pc doesn't recognise my camera ....thanks
USB connection will allow still photos ONLY to be capture to a computer. To capture the footage from the tape you will have to connect with a firewire cable, also called iLink or IEEE1394a. Windows Movie Maker will be one program that can capture the footage.
May 19, 2011 | Sony DCR-HC26E PAL Mini DV Camcorder
I can't initialize on FCP
If you are capturing HD, go into the menu > IN/OUT REC > i.LINK CONV and set it to off, and A/V->DV OUT to off. Go into FCP and go to the File Menu and select "easy setup". In the easy setup menu set the "Format" to "HDV" and set "Use" to HDV - 1080i60. Click "Setup". Now go to File > Log and Capture (command-8). You're now set to capture. Just queue your tape and hit "Capture Now" or set in and out points and capture "Clip".
If you want to capture SD footage, then on your Sony unit, go to the menu and set the i.LINK CONV to "on". In the easy setup menu you will want to set "Format" to "NTSC" and "Use" to DV-NTSC".
Sep 26, 2008 | Sony GV-HD700 HDV VCR
I want to connect a Panasonic NVGS120 by Firewire to a computer running Windows 7 or Vists. Is this possible? Does it need special drivers?
Yes it's possible. No special drivers.
Use a firewire cable to connect and open Windows Movie Maker to capture your footage.
Apr 30, 2011 | Panasonic NV-GS120 Mini DV Digital...
Hi, I am trying to import from my Canon MV 600 ( Tape not digital ) into a mac pro. I got the DV to firewire lead but the computer doesnt seem to recognise the camera. Many thanks Billy
Hi in order to get footage off your camera through Firewire i.e DV you will have to use a software to capture the footage. You can use iMovie to capture the footage off the camera.
Open Apple System Profiler (it's in the Utilities folder) and check to see if your camera appears in the FireWire section.
If your camera is connected via FireWire and is turned on, follow one or more of these tips to re-establish the connection to the camera.
  • Turn the camera off and back on again.
  • Disconnect the FireWire cable from your computer and reconnect it. Do the same at the camera as well. If the camera is connected through a FireWire hub, try connecting the camera directly to the computer.
  • Some cameras need to be set to "VTR", "VCR", or "DV" mode in order to communicate with a computer. Check your camera's documentation for information on how to set your camera to this mode if needed
Hope this helps.
Jan 17, 2011 | Canon MV600 Mini DV Digital Camcorder
Print to Video from Final Cut to GV-HD700 HDV has been impossible. What are the proper settings for both programs?
Depends how you are out putting the signal and the aspect of the original source footage. If firewire insure input select is hdv / dv, iee. And that remote is selected (if that deck has a remote option). Ensure the aspect ratio is correct as a sequence setting mark the area with an in and out and select in/out in the print to video window. Away you go, unless the tape is for broadcast (which I doubt as HDV is not generally a deliverable format).
Apr 15, 2009 | Apple Final Cut Express HD for Mac
PV-DV103 will not connect to pc via Firewire - Windows Movie makr
ur COMP. graphic is low. ur camera need capturing card on PC u can edit ur pic in movie maker
Mar 17, 2009 | Panasonic PV-DV103 Mini DV Digital...
Putting video footage on my computer
To get your footage into the computer from DV tape you need a four pin firewire (IEEE1493 or iLink) cable from the camera to a six pin cable into the computer. USB will not do a proper job, it's for downloding photos or as you already mentioned, Web caming.
Sep 15, 2005 | Panasonic NV-GS50 Mini DV Digital...
Sony Gv-hd700 Hdv 1080i Deck Hd Minidv Gv-hd-700 Logo
76 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
