Question about Frigidaire GLRS267ZA Side by Side Refrigerator
The ice maker makes humming noise but is not making ice
I have checked and the chute is not frozen.
  • 338 Answers
Sounds to me like the water control solenoid has failed and is not opening to allow water to flow into the ice maker.
Posted on Jan 20, 2013
SOURCE: My Frigidaire refrigerator (FRS20WNF)does not make ice anymore.
did you check your copper line in the back
Posted on Jan 14, 2009
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
SOURCE: ice maker will only make crushed ice
There is a rod on the back of the ice cube bin. It goes below a plastic slide in the back of the fridge. If yoiu pull the bin out and it does not engage right, you will be 'stuck' on crush. Pull the bin part way out and see whether the rod is going below or above the horizonal rung in the rear. If it is above, rotate the metal control until it will slip under the rung.
Posted on Apr 17, 2009
  • 125 Answers
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Posted on May 27, 2009
SOURCE: Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
Posted on Jul 28, 2009
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Tip
What to do if your ice maker stops working
Many refrigerators now come with built-in ice makers. Ice makers are very convenient, but occasionally they'll develop problems. Why pay a repairman to come out if the fix is easy and you can do it yourself?
Here are some tips for fixing an ice maker that stopped working.
- Check the on/off switch
Freezers with automatic ice makers have a switch that is used to turn the ice-making feature on or off. This switch is typically a rod above the ice box; when it's lowered, the ice maker is on, and when it's raised the ice maker is off. If the ice box fills up with ice, the ice can force the rod up, turning off the ice maker. Check this bar to be sure it is in the lowered position.
- Check if the auger or chute is clogged
Your ice maker has a chute where the ice falls from the freezer into the external tray (where a glass is placed). There is also an auger inside the freezer that rotates to drive the ice forward from the ice box into the chute. Check the chute for large chunks of ice that may be clogging it up, and check the auger for ice cubes or chunks that might have gotten wedged between the auger and the freezer, causing the auger to be unable to rotate.
- Check the water line
If you still haven't found the problem, check the water line leading into the freezer. This water line has its own valve. Make sure the valve is open, allowing water into the freezer to create the ice.
on Jan 23, 2011 | Refrigerators
Ice maker make noise and back of freezer is frozen
THE DEFROST CONTROL IS OUT MAY BE THE DEFROST BYMETAL OR A TIMER OD DEFROST HEATER WHAT BRAND AND SIDE BY SIDE OR TOP AND BUTTEM REF. AND AGE. WILL HELP
Feb 21, 2012 | LG LSC27910 (265 cu ft) Side by Side...
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
May 31, 2009 | Maytag MSD2454G Side by Side Refrigerator
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Icemaker stopped making ice
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
May 24, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice Maker won't work...water line frozen?
HOLLOW ICE FOLLOWED BY FROZEN WATER CHUTE ARE THE FIRST SIGNS THAT THE WATER INLET VAVLE IS OR HAS FAILED, IT CAN ALSO CAUSE DAMAGE TO THE ICEMAKER BY BURNING OUT THEN TIMING GEAR DUE TO INSUFFIENT WATER OR FLOODING IN ICEMAKER WITH TOO MUCH WATER
Apr 29, 2008 | KitchenAid KSRS25IL Side by Side...
Humming in Whirlpool Side by Side Refrigerator
It is probably just your water inlet solenoid being activated. Not to be concerned.
Sep 26, 2007 | Refrigerators
Frigidaire GLRS267ZA Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
